Integra 9.8 & hdmi sound
dholmes
dholmes Posts: 1,136
edited June 2008 in Electronics
Im doing something wrong with my 9.8 & Pany 30,I have a single hdmi cable for sound & pic ,Ive set the blu-ray player to bitsteam,the disc to dolby hd but the dolby hd doesnt light up on my 9.8.I tried with a dts hd disc & it does the same thing,the sq is great but neither dts hd ma or dolby hd lights up.Ive got dts neo & pllx2 on dolby,what have I set wrong?? The 9.8 says pcm.thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • dholmes
    edited June 2008
    Anyone !
  • MikeC78
    MikeC78 Posts: 2,315
    edited June 2008
    Good question? Seems like you are doing everything right, what happens when you set the Panny to PCM?
  • dholmes
    edited June 2008
    thanks tried that,at the avs forum they gave me few ideas.
  • cheddar
    cheddar Posts: 2,390
    edited June 2008
    How about seeing if you can get bitstreaming to work or not over optical first? It does seem the 9.8 thinks it's dealing with PCM, so the problem might be on the panny side. I'd go through and see if there is any setting you need to adjust in the player to enable bitstreaming specifically for hdmi.
  • millerman 3732
    millerman 3732 Posts: 1,488
    edited June 2008
    cheddar wrote: »
    I agree it seems like it has to be something on the player side if your Integra is receiving a PCM signal. In the player setup menu make sure you have all the output formats set to bitstream, you will have to do each one individually.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • dholmes
    edited June 2008
    Thanks,the guys at avs said I need to set the second bd video to off your sceen says on,also on the hdmi audio out set it to off
