Tube Preamp with Pass-Through?
AsSiMiLaTeD
AsSiMiLaTeD Posts: 11,728
edited June 2008 in Electronics
i have a buddy with a Sunfire Grand Cinema preamp hooked to a Parasound 5 channel amp. I've got him hooked on tubes, but now have a new obstacle.
He wants to be able to still use his Sunfire for movies and such, but be able to use a 2 channel tube preamp for music, so I'm thinking an amp with pass-through would work. Run from the Sunfire to the tube preamp to the amp, and when the tube preamp is turned off or whatever the signal from the Sunfire is passed through to the amp.
That make sense, any suggestions for preamps with this capability?
Post edited by AsSiMiLaTeD on
  • amulford
    amulford Posts: 5,020
    edited June 2008
    Check out VTL. More specifically the TL2.5, nice neutral, and simple circuit
  • SolidSqual
    SolidSqual Posts: 5,218
    edited June 2008
    Dodd, Odyssey, BAT, Cary . . . I have a big vote for the Dodd.
  • AsSiMiLaTeD
    edited June 2008
    The Dodd I have doesn't have pass-through, which model of his has it?
  • Ricardo
    Ricardo Posts: 10,634
    edited June 2008
    MLP has it, and I am pretty sure the Reference also has it.
    SOPA
  • SolidSqual
    edited June 2008
    Polkmaniac wrote: »
    The newest and only one he is making right now.
    http://www.doddaudio.biz/web/product_view.html?product=1
    Battery Powered Preamps
    Continuously Running, Battery Powered Preamp
    I believe this to be the first of it's kind in the world, at least the only one contained all in one chassis. I am very proud of this preamp and have been working on it for three years. In fact, this preamp is so good that I have discontinued the older preamp models. Check out some of the awesome features this preamp comes loaded with...
    Fully self contained in 1 chassis
    2 sets of batteries for continuous operation
    Charges using a small plug-in charger
    Uses any tube from the 6DJ8 family
    Cardas and Vampire copper RCA's
    Vampire CCC18 wiring
    Sonicap and Sonicap Platinum output caps
    Hardwood and piano laquered finishes
    Remote control volume with matching remote
    Home theater bypass (unit does not have to be on to function)
    Curly Maple or Rosewood wood chassis
    This unit is $3,300, either finish.
  • Gaara
    Gaara Posts: 2,415
    edited June 2008
  • phipiper10
    phipiper10 Posts: 961
    edited June 2008
    Anthem pre-2l (se) has pass through and remote - good tube rolling ta boot. About $500 - $600 used
    Might not have the sleekest most modern look but I'm happy. I'll be changing amps before this pre.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
