Inputs location when Front Firing DSW
jb1013
jb1013 Posts: 12
Can anyone tell me the orientation of the inputs when you put the DSW Sub in Front Firing Mode.
Are the inputs on the bottom, L, R, or Rear, if your facing the speaker cone that is firing forward?
Thanks,
Jason
Post edited by jb1013 on
  • MADGSF
    MADGSF Posts: 603
    edited June 2008
    bj1013, I havie never seen this sub so I can't comment. I suggest giving Polk Customer Support a call, they will be able to tell you.
    800-377-7655
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • Rivrrat
    Rivrrat Posts: 2,101
    edited June 2008
    When you look at the pics on the Polk web site, it looks like the amp, inputs etc will be facing the floor.
    My equipment sig felt inadequate and deleted itself.
  • dorokusai
    dorokusai Posts: 25,576
    edited June 2008
    jb1013 wrote: »
    Thanks,
    Jason
    Bottom.
    This is just an EXAMPLE of what you might want to use as a connection adapter, if setup as front firing.
  • jb1013
    jb1013 Posts: 12
    edited June 2008
    Thanks everyone. That was the conclusion I was coming to as well by looking at the documentation. I was hoping the documentation was wrong. Seems like they could have planned that better.
  • dorokusai
    edited June 2008
    The configuration was for folks that would typically place the subwoofer in a cabinet, so I'm not sure what would have been a better idea. What exactly could have been planned better? I agree that an angle adapter makes things better but aside from that.....
  • Eric W
    Eric W Posts: 556
    edited June 2008
    jb1013 wrote: »
    How would you suggest doing it?
    -Eric
    -Polk Audio
