Optical Jacks
Is using the optical jacks for audio and the "orange" coaxil for video still the best connection?
And I mean calling all cars, blackhawk down, mushroom cloud, Three Mile Island, lock the door behind you kind of mad.:mad:
Post edited by paymontna on
Welcome!
    edited June 2008
    The best connection for what?
    The "orange" coaxial has not been the best connection for video in at least 10 years, maybe longer. There is S-video, component, and now HDMI.
    edited June 2008
    WilliamM2 wrote: »
    Ok, I am on the right path I am using component for the video and optical for the audio. Is HDMI better audio quality than the optical wires?
    edited June 2008
    HDMI can carry a higher bandwidth.
    edited June 2008
    The orange coax is not video, but audio.
    Ben
    edited June 2008
    paymontna wrote: »
    If the you are only using a single orange lead for video, it's not component, it's composite.
    I doubt HDMI has better audio quality, but it should be the same, and it also carries the video signal at the same time, which means you only need one cable.
    You still didn't tell us what it is you are trying to connect.
    edited June 2008
    Yellow = Composite Video Input/Output.
    Orange = Digital Coaxial, Audio Output/Input.
    Unless you have a need for higher bandwidth, stick with the standard coaxial output for audio.
    edited June 2008
    I'm not sure if HDMI is higher quality in format, but like Face said, it does carry higher bandwidth, thus can support a higher quality signal; ie. DolbyTrue HD.
    edited June 2008
    I am using the digital optic (red light) cables for hook up from my Sony DVD to my Denon 803 AVR, and from my cable box to my AVR. That is for audio. Now what is the orange coaxial that is coupled with the optical hook up? I can use that instead of component? That would make it more simple right?
    edited June 2008
    edited June 2008
    The orange coax is digital audio just like the optical you are currently using; same signal, different mode. You only need to use one of those (orange digital coax or digital optical) for your audio and you will be covered.
    As far as video goes, here is usually the preferred order of picture quality: HDMI, component (red, blue, green coax), composite (yellow coax). Choose one of those are you will be covered on the video.
Welcome!
Welcome!
