Can out-of-range frequencies hurt your speakers?
xandra
Not sure if this should go here or in the Speaker forum...
the title says it all "Can out-of-range frequencies hurt your speakers?"
I ask because of 2 situations:
Situation 1: Some Multitrack SACD's seem to send frequencies I assume to be out of range (too low) for my CSiA3. Yammy DVD/SACD -> OnkReciever. (crossover is set to 80)
In general it APPEARS that the Yammie ignores bass management on SACD's...Doesn't matter if running thru Multichannel or HDMI (comes in as PCM),
I've noticed tones as low as Bflat 2 octaves below middle C (have no clue what freq this is but sounds mighty low) More importantly one of my SACD's seems to create a buzzing sound on notes too low for my ears to identify.
Situation2: I've got RTi4's in my BR (no Sub) so everything must play thru the teeny speakers... will this cause damage at lower volumes? (obviously no way to avoid sound effects)
LR Setup:
Polk RTi10's, RTi6's, CSiA6 (5 ch setup)
Onkyo 705 & Denon 3808ci Receiver, Onk 875
Parasound 2250 Amp
Sony 26" KDL series Bravia LCD
Panny DMR-EH75 Recorder
Panny DVD-F87 (5 disk DVD player)
NAD T585 (DVD/SACD)
Yamaha DVD-C961 (5 disk SACD/DVD)
SciAnt Explorer 8500HD Cable Box
Orig & 5Gen iPods, , Wii
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability.
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Post edited by xandra on
Since it appears to ignore your crossover frequency, can you set the center to small?
Lower volumes shouldn't hurt anything."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Yes, it's set to small. But the Yammie seems to disable bass management on SACD's... unfortunately it SOUNDS like the Onk won't override Yammie's output when playing SACD thru HDMI. (theoretically you're not supposed to impose base mgmt on SACD - this sounds great in most instances, but in some cases it really puts the speakers to work beyond their limits)LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
400 disk player that handles ALL formats, sounds as good as NAD with Panasonic interface & compatability. -
Does your Yammie have HDMI 1.2 or higher? If not, it won't play SACD as DSD. Most players have HDMI 1.1 with only a few more on the market now with 1.2a and higher.Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200 -
Yes, it's 1.2a.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
Generally the answer is no so long as youre not overpowering your speakers. Too much power will kill any speaker regardless of frequency.
A 5.25 speaker will usually roll off natrualy at around 50 Hz and drop off pretty quick from there. The only real negative is that it will screw up your sound. While a 5.25" mid can play down to 40 Hz it cant do so with any real authority and since its having to strain to hit those frequencies it can cause the driver to distort and mess up your midrange.polkaudio sound quality competitor since 2005
MacLeod... that sounds like just about what happens with the RTi4's in BR.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
sub sonic (out of range) frequencys can dammage your speakers, this can only happen at moderate to high power levels. its a bigger problem with pro/pa speakers, if you dont bypass the bass from these it can easily result in over excursion (speakers hitting end stops), or as i found out with my sub from overpowering you send the former/coil off the end of the magnet.
you will know about it if you hit the "stops" and as MacLeod said when overpowerd it notecably detiriorates the sound coming from the driver. my wharfedales dont seem to have a end to their excursion but when you overpower them (alot) the sound from the bass/mid driver loses its composure. and power compression sets in (i think)ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
ward - THANKS: I was afraid of that. Just spoke with (another) great polk techie who confirmed exactly what you said... it has to do with the coils.
BUMMER: Now, what to do about this?!?!! The only way I seem to overide is to listen via HDMI and enable some listening mode that uses the ".1" channel. (hardly the ideal for playing SACD's)
Might need start another thread with SACD in title with hopes of finding others who've run into same issue.LR Setup:
Parasound 2250 Amp
NAD T585 (DVD/SACD)
Plans/Fantasies:
