How do I eliminate the noise?
MKZ
MKZ Posts: 1,068
I have start messing up the system by adding some Signal power cords. It starts making static noise after playing 8 or 9 songs sometimes 10. It also happened on after playing few min of fm also.
I only need the signal digital reference for the pre-amp. I have also separate the cable as much as I can but the Kimber are not shielded.
I’m using AudioQuest CV-4, Signal cable for Speaker Cable and Kimber PBJ, Timbre and AQ CopperHead for IC. I like to know how do I eliminate the noise? I appreciate for any helps.
Post edited by MKZ on
  • zingo
    zingo Posts: 11,258
    edited June 2008
    Are the IC you are using directional?
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited June 2008
    If this only happens after the unit warms up, I doubt it's the cables. You may have a problem with your amp/reciever.
    Does swapping the new power cables with the old ones eliminate the problem?
  • MKZ
    MKZ Posts: 1,068
    edited June 2008
    zingo wrote: »
    CopperHead, yes.
  • MKZ
    MKZ Posts: 1,068
    edited June 2008
    WilliamM2 wrote: »
    Yes, I did for magic power cord for amp but not digital reference since I misplaced oem cord and it doesn't eliminate completely. When I go very close to speakers I still hear it may be I wasn't notice before.
