cd players
Home Theatre
can someone please recommand a good cd player in 125-200 dollar range?
I would like a 5 disc changer.
I am using a hd-dvd player by toshiba right now.
Everything I own burned in the fire!!!!!!!!!!
Post edited by Home Theatre on
Home Theatre wrote: »can someone please recommand a good cd player in 125-200 dollar range?
Onkyo DX-C390 - great player in your price range."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
I like my Sony SCD-C2000ES but you might have to pay $250-$300 for it unless you're patient enough to wait for a good deal.
I see them on ebay for about $250 shipped. Crutchfield has a scratch & dent for $299.
Plus it's a SACD player. -
Marantz CC4001, hands down a solid player, very heavy,Cirrus Logic CS4392 DAC and sounds outstanding, google it and you can find them used in your price range. I paired mine up using Signal Cable Analog II ICs, a magic power power cord and it does a superb job. You maybe able to find it new on Onecall in your price range as well.Shoot the jumper.....................BALLIN.............!!!!!
If you can find it used, the XCD-88 offered by AV123 is also very good. Usually go for around $200.
Edit: Sorry, didn't see you were looking for a changer. -
If you get a 5-disc changer in your price range, you should expect it to sound worse than the Tosh, then you won't be disappointed if the player meets your expectations.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I second Sheradp's Marantz suggestion. Good player for the money.
Here's a good un'
http://www.accessories4less.com/make-a-store/item/MARCD5001/MARANTZ/CD5001-Single-Disc-CD-Player/1.html
I have the Martantz CD5001 (the one to which the link above is provided). I love it. It was a big step up from my old Sony player in sound quality, but it is, after all, a single disc player (this is what I wanted). If you want a 5 disc changer you might consider, as someone posted above, the Marantz CC4001. The same store, Accessories for Less, also has a refurb for the same price,
($190). http://www.accessories4less.com/make-a-store/item/MARCC4001/MARANTZ/CC4001-5-Disc-CD-Carousel-/1.html
If you want a new one (with a 3-year warranty), it can be had for $330. Just go to Amazon and you'll see that a few authorized dealers (One Call, Sixth Avenue, etc.) carry it and offer free shipping.2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects -
Should I take a chance on a marantz dvd player begin sold on craigslist for my listening enjoyment.
12 years old.
40 bucksEverything I own burned in the fire!!!!!!!!!! -
Oh, I thought you were looking specifically for a CD 5-disc carosel/changer, not a DVD player. If you're going to go that old, I think that any reputable brand (at that price) would be fine. I had a Sony CD player that I bought for $100 in 1993 and its still working fine. I just replaced it with the Marantz, but there were no issues whatsover with the Sony. If you just need a DVD player go for it.
But if you want a 5-disc changer, I'd still consider the Marantz CC4001 (mentioned above). Its a little pricier ($329 brand new) but you get a 3-year warranty with it, just in case anything goes wrong.2 Ch.
HT
Denon 2808ci AVR
Or you could go with that refurb for $190 (though I think the warranty is reduced to one year or something)2 Ch.
HT
Denon 2808ci AVR
Home Theatre wrote: »Should I take a chance on a marantz dvd player begin sold on craigslist for my listening enjoyment.
12 years old.
40 bucks
nope... 12 yrs is pretty old.. get a CD player like the cheap one I have.. I think it's a Marantz CD4300 5 disc carousel
http://cgi.ebay.com/Marantz-CC-4300-5-disc-CD-changer-player_W0QQitemZ130227542968QQihZ003QQcategoryZ14975QQssPageNameZWDVWQQrdZ1QQcmdZViewItemPolkFest 2012, who's going>?
