Bridging Amplifiers
joeparaski
joeparaski Posts: 1,865
edited May 2008 in The Clubhouse
I always thought that you can't bridge amplifiers unless they were designed to do so. Until I found this..... http://www.avahifi.com/root/equipment/bridge/index.htm
Any thoughts?
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    For that price I would sell the amps I was going to bridge, and buy what I was looking for power wise. I would have to question the SQ, and the reliability of the amps after using such a device. No matter how you bridge the amps would still see an 8ohm load as a 4, and a 4ohm as a 2.
    Ben
    F1nut Posts: 51,938
    edited May 2008
    ^ What he said ^
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited May 2008
    Well I was a bit shocked on the price myself, as I could do it with a handful of parts under $15 bucks. An op amp and a small power supply, I understand that maybe higher quality but $650. I'd be pissed when I opened that up. So I'm in 100% agreement with Ben.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited May 2008
    Okay, so here's the diagram for bridged mono operation with two amps:
    So (and I'm in Learning Mode here), on the pre-outs, you're taking the "normal" hot left to the left speaker, and the "normal" hot right to the right.
    This gizmo than takes the those "normal" hot signals, inverts them, than sends inverted left to the left speaker, and inverted right to the right.
    Got that (I think).
    So .... they say, "There is no better way to get such extraordinarily high power"
    Well ..... wouldn't the weak link still be the power/quality of the power amps ?
    "This sums the voltage swing of the two channels,
    ....got that. Simple electronics.
    " at least triples the power, "
    ....that depends on your power amps' guts, right ?
    You have an Onkyo 100 watt/channel amp, you're not going to find some miraculous 300 watts out of ether, correct ?
    " and eliminates common mode distortion.
    .... that may be true. In fact, it probably is.
    But the inversion process will introduce time lag; it has to.
    What effect this has on the end result (you sitting in your sweet spot) is unknown, I guess. But there has to be an effect.
    Wouldn't a better route be to simply juice up your power amps with common ground amps ?
    Inverters are good for driving variable speed motors, but ..... I don't know about their use for audio.
    Inverters are "noisy", so I guess you better spend a couple of hundred extra bucks for shielding.
    :confused:
  • Serendipity
    Serendipity Posts: 6,975
    edited May 2008
    IMO it's not worth it, you could buy a better amp for $650.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2008
    Soundcraftsmen used this same approach with the AB-1 bridger for bridging of their stereo amps. The AB-1 was like $49 though....
  • unc2701
    unc2701 Posts: 3,587
    edited May 2008
    If you have XLR inputs or a phase switch (for each channel) on your amp you can do it for a few bucks. AMPS MUST BE COMMON GROUND!
    Phase switch:
    Flip the phase on one channel, y adapter so L&R channels get the same signal (but one will be flipped phase); tie ground posts (black); speaker wires go to hot posts (red)
    XLR:
    If you've got xlr output on your pre, just get an XLR y-adapter, flip the +/- pins on one side of the adapter; tie ground posts (black); speaker wires go to hot posts (red)
    RCA (With XLR input on amp):
    Again, take an RCA Y-adapter; On one channel you'll put the RCA tip to the +XLR and tie the RCA ground to the -XLR and XLR ground; On the other channel put the RCA tip to the -XLR and tie the RCA ground to the +XLR and XLR ground. As above, tie ground posts (black); speaker wires go to hot posts (red).
    With the last method, you'll lose 3 db of gain on the input stage, but you've got the extra headroom.
    If you only have RCA inputs, then yep, it's a $15 circuit to flip the phase for the one channel.
    Backburner:Krell KAV-300i
  • ShinAce
    ShinAce Posts: 1,194
    edited May 2008
    Can't you just couple many outputs with transformers to make them float?
    Bam! 10 amplifiers on 1 speaker.
