2Bs half fixed.Right channel inner driver still out
fbm211
fbm211 Posts: 1,488
edited May 2008 in Vintage Speakers
Well I took apart the speakers and found in the left channel that the crossover wasnt connected to that round coil thing above the speaker input terminal.The right channel one was.And "After" I connected the interconnect cable the outer driver started to work in the left channel.However the inner driver in the right channel still doesnt work.Ohm meter says its ok.So I will have to take that apart again and hope its a break in the wire.If its the crossover do they still make those??
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    I don't know if they still have them in stock, but for the replacement price you could easily do the upgrade, and have better than stock. I am doing one for a fellow Polkie now. I am just waiting on the caps to come in.
    Ben
    Ben
  • Face
    Face Posts: 14,340
    edited May 2008
    I don't believe they make them anymore, but as Ben mentioned, now would be a good time to upgrade.
    F1nut Posts: 51,944
    edited May 2008
    The crossovers are not available. However, you should be able to repair and/or upgrade yours.
  • fbm211
    fbm211 Posts: 1,488
    edited May 2008
    Well I would be willing to pay someone to do it for me if it turnes out to be something I cant figure out.
