wiring for seprates in 06 Silverado
Chris Velardi
I've got an '06 Silverado 2500HD extended cab that I'm putting a pair of Polk DB6501's in the front doors . The Silverado already has separate wiring for the tweeters and main cones , but I don't know where or if an active or passive crossover was used from the factory to separate the signals. The new DB6501's come with a cross over that I would like to use. I'm just not sure which wires int he door to use, or where the stock cross over is located so I can replace it. (my Silverado has no Onstarand no Bose Lux) Soon to have no Bose speakers
Thanks in advance
Thanks in advance
Chris "V"
Post edited by Chris Velardi on
You'll probably get more answers to your question of you post your thread on the Car Audio and Electronics section of this forum;) Welcome to Club Polk!Fronts: RTI10's
Center: CSIA6
Rears: RTIA3's
Sub: 15" Velodyne DLS5000R x2 Stacked:D:D:D
Amp: Marantz MM-9000 150wpc (bi-amped for RTI10's) and CSIA6
Blu-Ray: PS3
Harman Kardon AVR247
Monster Cables
Signal Analog II IC's
Panamax MP-5300 Power Conditioner -
Double true...You'll probably get more answers to your question of you post your thread on the Car Audio and Electronics section of this forum;) Welcome to Club Polk!
I would pull the door panel and take a look. I would think the x-over would be in there with the separates, but the cars guys would know better. -
I Just realized there was a separate car section , that would be better than wiring sorry. In the door there is no cross over that is why I'm confused as to which wires to use.Chris "V"
