Polk RTA 12B Tweeter fuses
rmaiers
rmaiers Posts: 145
edited May 2008 in Vintage Speakers
I recently acquired a set of Polk RTA-12B speakers powered by a Hafler DH-500 amplifier/DH-110 preamplifier. I soon started blowing the .75 amp fuse for the tweeters and upped it to a 1.0 amp fuse. I am still blowing fuses at around 1200 on the volume (which is very loud). The Hafler has more than enough power/current for these speakers so I am wondering if there is a problem or if the Hafler has too much power. Any thoughts are appreciated.
Post edited by rmaiers on
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    Well those fuses are their to protect your tweeters. Clean power is much less likely to blow tweeters than dirty power. You can use a higher rated fuse, but you would risk blowing the tweeters. If you hear distortion at all you should turn it down. I hope this helps.
    Ben
    BTW if you blow your tweeters it would be a good excuse to get the new replacement tweeters with silk domes to replace the old ones:)
    Ben
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2008
    You should ease off the volume knob for now, use 1A250V fuses and order new polyswitches from Polk. The amplifier isn't too much for the speaker....you probably are. Sorry, no offense. Here's the contact information:
    polkcs@polkaudio.com
    800-377-7655, Option 1 toll free
    410-764-5470 fax
    International +1-410-358-3600
  • ben62670
    edited May 2008
    The fused 12's didn't have Poly switches in them. They could be implemented, but that would require modding the XO. I think keeping the fuses would be a good Idea. It might get a little tiresome to keep changing fuses, and may lead to some self discipline:p
    Ben
  • dorokusai
    edited May 2008
    I don't think we really know anything unless we get some pics eh?
  • ben62670
    edited May 2008
    dorokusai wrote: »
    I'm just going off schematics rocket boy but thanks.
    Thats where I was looking, and none of the 5 schematics I looked at had both a Poly switch, and a fuse.
    Rocket boy:confused:
    Ben
  • ben62670
    edited May 2008
    dorokusai wrote: »
    Yeah. We both know how there are many in transition models out there:D
    Ben
  • dorokusai
    edited May 2008
    Amen. This is as reliable as the Monitor series.
  • danger boy
    danger boy Posts: 15,722
    edited May 2008
    ben62670 wrote: »
    Ben
    I wouldn't recommend he get the new silk dome tweeters till he solves the problem with the blown fuses.. or else he runs the risk of blowing the new tweeters :eek:
    PolkFest 2012, who's going>?
  • rmaiers
    rmaiers Posts: 145
    edited May 2008
    Thanks for all the input. I have been getting a little carried away with the volume but this is the best system I have ever owned and it sounds fantastic at high volume. My wife is complaining that she has to straighten the pictures in the house after one of my high volume sessions. Guess I'll back off and keep fuses on hand.
  • dorokusai
    edited May 2008
    That sounds like the solution :D
