The secret "brown box" finally arrived
Early B.
Early B. Posts: 7,900
edited May 2008 in Electronics
After waiting 10 weeks, the custom Promitheus Transformer Buffer has arrived. It's kinda cool -- I may be the only one in the world with one of these things. The unit was shipped via DHL on Monday from Malaysia, stopped off in Hong Kong, then made its way to the USA.
Background -- I used to own a Promitheus TVC. It provided outstanding tonal quality to the music and was considered the best upgrade I ever made. I sold it because of the gain issue that plagues nearly all TVCs. With my associated gear, I couldn't get sufficient volume.
Enter -- the Promitheus TB >> it is simply a buffer that I placed between my CDP and pre/pro. I'm hoping to get the best of both worlds -- that transformer quality sound and the ability to use the volume control and remote from my pre/pro. It only has one set of inputs and outputs. It also has a separate digital input and output in case I decide to run a DVD player through the buffer or use a DAC or whatever. It also has a switch on the back to "turn off" the transformers. That way, I can toggle back and forth to determine the effect the transformers have on the music.
I'm breaking it in right now on some Regina Belle. I'll report back later on my initial impressions and post some pics, although it ain't much to look at -- it's basically a wooden box (although the wood is very nice).
"God grooves with tubes."
Post edited by Early B. on
  • Early B.
    edited May 2008
    Here are some pics:
  • Early B.
    edited May 2008
    I installed the TB and I'm getting a very noticeable hum through the right speaker only. How do I get rid of it? I'll check my connections again. And how do I use the ground thingy on the back of the unit? Will that cure my hum problem?
    Thanks.
  • pearsall001
    pearsall001 Posts: 5,299
    edited May 2008
    EB...man are you off the deep end, all in a good way of course! :D What the hell is it & better yet...what is it supposed to do???? Where do you find this stuff! Good luck with it, & throw a cheater plug on it & that should solve your hum problem, I think!
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    Good luck throwing a cheater plug on something that doesn't plug in, i guess that answers my question if it is unity gain or not. Only time I ever got hum with my TVCs was a bad interconnect.
  • Ricardo
    Ricardo Posts: 10,636
    edited May 2008
    Early B. wrote: »
    By pass it??
    :p
    I would try connecting that ground to the chassis of your pre, but that's just a guess since I don't even know what that thing's supposed to do.....
    SOPA
  • Monster Jam
    Monster Jam Posts: 919
    edited May 2008
    Looks like something from Gilligans Island that the professor kit-bashed in his tree-house! :)
    Do you hear that buzzing noise? :confused:
  • hoosier21
    hoosier21 Posts: 4,418
    edited May 2008
    I understood the Promitheus TVC and what it did, but this thing???? I will have to read up on it and what it is suppose to do.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • hoosier21
    edited May 2008
    don't see it on the website, wtf is this thing?
  • Early B.
    edited May 2008
    hoosier21 wrote: »
    Well, since it's probably the only one in existence, you won't find anything to read until I post my initial impressions.;)
  • SolidSqual
    SolidSqual Posts: 5,218
    edited May 2008
    How did you get the idea to do this and how did you convince them to make t for you? Do they normally do custom work like this. I'm still trying to understand what it actually does. Pretty cool looking though.
    treitz3 Posts: 20,016
    edited May 2008
    Good Gawd. You guys don't know what this does?.......Bunch o' rookies.......:rolleyes:
  • SolidSqual
    edited May 2008
    Rookie? Care to explain how Early's box works?
  • Early B.
    edited May 2008
    It's a buffer. Think about what a tube buffer does -- it imparts a tube sound onto your system. This is similar, except instead of tubes they're transformers. It's a TVC with out the "VC." Simple and plain. Got it?
    If you wanna learn more, google "transformer volume control" and read about the value of introducing transformers into your system, primarily to take advantage of impedance matching.
  • unc2701
    unc2701 Posts: 3,587
    edited May 2008
    What's the winding ratio?
    Backburner:Krell KAV-300i
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited May 2008
    Russ, it's a silly peice of gear, for a silly member.
  • miner
    miner Posts: 1,305
    edited May 2008
    Is that David Bowie's TVC-15?
  • Face
    Face Posts: 14,340
    edited May 2008
    I don't see what the advantage would be of running a digital cable through it.
  • unc2701
    edited May 2008
    Digital cable doesn't go through the transformers- it just goes through a toroidal choke. But I wouldn't be surprised if there was already one inside the digital source or pre-pro.
  • NotaSuv
    NotaSuv Posts: 3,871
    edited May 2008
    what was the cost of this one of kind from the other side of the world? are they made to order, or this was just a one of a kind you located....thanks
  • Face
    Face Posts: 14,340
    edited May 2008
    unc2701 wrote: »
    Yes, so why add another one?
  • unc2701
    edited May 2008
    Well, given the two large antennas that it's sitting right in the middle of, a choke is probably a good idea. :rolleyes:
  • tryrrthg
    tryrrthg Posts: 1,896
    edited May 2008
    Why not just get a nice amp that is built around the use of a passive pre so you can use the TVC? My old McCormack amp was designed around it being used with McCormack TLC1 passive pre. Sounded great together.
    edited May 2008
    Early, give me a jingle sometime tomorrow. SS, I actually had no frikin' clue as to what this did/does. I was just razzin' y'all. :p
  • Early B.
    edited May 2008
    OK, the hum problem has been fixed. It's dead quiet now. A mini-review is forthcoming.
  • SolidSqual
    edited May 2008
    treitz3 wrote: »
    Hehe . . . yup I figured. But, since you're older than me I have to respect the experience.
  • Gaara
    Gaara Posts: 2,415
    edited May 2008
    Early B. wrote: »
    So what was it, bad rca, bad solder joint, other? Can't wait for the review.
  • Early B.
    edited May 2008
    SolidSqual wrote: »
    Post #14 didn't explain it well enough?
    That''s OK. In my mini-review, I'll go into a little more detail about how it works, although I don't completely understand all of it myself. But that ain't important. I don't know exactly how my CDP, amp, pre/pro, and other gear actually works, nor do I need to know.
  • Early B.
    edited May 2008
    Gaara wrote: »
    No. I had to "jump the transformers" by soldering a couple of wires. No problem at all once I understood what to do.
  • Early B.
    edited May 2008
    I’ll provide my initial impressions of the Promitheus Transformer Buffer (TB), but first I’ll quote from a review I did last year on the Promitheus TVC because all of it is applicable to the TB:
    The TVC brings out all of the subtle nuances of the music. I like how it presents the music at very low volumes. Even at whisper quiet levels, the TVC has the bass and transient attack of a good active preamp.
    The TVC has great tonality. Instruments sound natural and balanced. Equally impressive is the decay of instruments. In many solid state systems, decay is usually truncated, but the TVC creates a very natural decay that would make many tube amps envious.
    The best aspect of the Promitheus is a lush midrange with no harshness whatsoever.
    The Promitheus TVC is the best audio purchase I’ve ever made.
    OK, so what was the before & after effect? Well, the sonic improvement was substantial, especially the decay of instruments as noted earlier. That’s not surprising due to how the transformers impact the sound. Here’s why – for maximum power transfer, ideally you want identical source/load impedances. Your amp wants to “see” a low output impedance to complement its own high input impedance. Since transformers lower the effective output impedance of the CDP, there's a more optimal impedance transfer to the amp, which translates into improved sound quality. That's because the CDP is supplying less current to drive the amplifier's input impedance to the same voltage level.
    As a result, I can now decrease the volume on many of my CDs and still hear the dynamics and clarity. Most impressive is the accuracy of cymbals and bells. Also, live music is tremendously life-like. When the audience claps, it sounds like you’re right there clapping along with them.
    I should add that the emotional impact of the music is absolutely breathtaking. Gentlemen – listening to female vocals will make your wee wee dance in your pants. The TB literally allows you to experience more music, not just hear it. Also, the sound is thicker and richer than before; despite being more mellow, it has a lot more body and weight to it.
    The Promitheus TB is precisely the sound I wanted. I heard it before when I owned the Promitheus TVC, now it’s back and even better due to changes I made in my system. I also like the fact that the TB was very cost effective, especially for a custom made component. I like the plain brown box, although it needs a small logo or something on it.
    Here’s the bottom line – this buffer creates an awesome, emotionally-involving sound quality. Keep in mind that I’m using an HT pre/pro and multichannel amp! A muscular two-channel amp is coming in the next month or two, and my system will likely sound even better. I’ll probably keep the pre/pro in the loop for convenience and cost, at least for a while. I’m very satisfied with the buffer’s performance and look forward to listening to all of my favorite CDs again and again.
