08 escape db212
darthlaidher
hey yall im new here, but anyway im loving my new 12's but if i turn my volume up past half way my whole hatch vibrates, the hatch door vibrates the glass everything does except for the license plate (used a old sock to stop it vibrating) does anyone have any tips to stop this besides turning down the volume?
Post edited by darthlaidher on
dynmat everything, put carpet insulation between the panels.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
my bad, carpet padding.2013 Toyota Prius
Mosconi 6to8 v8 -
dynmat is pretty cheap to get im guessing?
darthlaidher wrote: »dynmat is pretty cheap to get im guessing?
The original stuff is fairly cheap but the Xtreme is much better (though expensive). Second Skin's Damplifier Pro is a better value IMO.
http://www.sounddeadenershowdown.com/ -
heres my new subs. im thinkin about gettin 2 10s and maybe putting them on top of those... or is that over kill? -
yeah, those look freaking legit, ive always thought they did a good job. overkill... nothing is overkill
u may want to see whats behind u though... 2013 Toyota Prius
Mosconi 6to8 v8 -
i got them for cheap too 179 dollars on sale then they rung them up n they went down to 142 dollars. so i was pretty excited.
i never used dynamat before can you stick that over windows or no?
i seen db 124's at circuit city for 312! wtf
i was trying to ghetto rig my ride with padding i sorta got it fixed all that rattles now is the glass window on the hatch. i can see that **** flexing like a ****. my mom said when i was playing it i was rattling all the windows and the back door at our apartment lol -
yea, same problem with the blazer. Even leaning on the back glass doesn't keep it from rattling, although I will probably end up getting the dynamat license plate stuff to keep that from goin ****. same subs in my car, they sound awesome, congrats.2000 Chevy Blazer
db212-2 -
⊙ ⊙ say:good..portarit2000
SPAM!
