Amp Deal of the Century!
1234689
    billbillw Posts: 7,598
    edited May 2008
    madmax wrote: »
    At the original price I would not have bought one but for $15 its a no brainer. They sound good.
    From the website, for two amps, it works out to about $20.50 a piece w/shipping/tax...still a real steal! The current T-amp goes for $50+shipping from P.E. Two of these for less than one T-amp.
  • maximillian
    maximillian Posts: 2,149
    edited May 2008
    Does it clip running them at reasonable levels? If that is the case, then I don't want to drive any of my "good" speakers and run the risk of blowing a tweeter.
  • madmax
    madmax Posts: 12,434
    edited May 2008
    It could but you would be able to hear it. Worst case amp for speaker damage is at about 100 watts per channel. This amp is maybe 30 or 50 wpc.
    Vinyl, the final frontier...
  • ben62670
    ben62670 Posts: 15,969
    edited May 2008
    No problems driving speakers at pretty high levels. A couple minor mods are in order to get surprisingly good results out of these little gems. Bypass the whole front board which ditches the lame tone controls, cheap pots, and SQ killing caps they have all over the thing. Really simple, and someone would be glad to help you through if you needed help.
    Ben
    Ben
    edited May 2008
    ben62670 wrote: »
    Ben
    Assuming I would want to use this for a computer rig, what would you be using for volume control if you removed the entire tone control board? Is the range of the volume control in Windows enough to control this adequately or do you need to install a separate volume pot?
  • ben62670
    edited May 2008
    billbillw wrote: »
    Correct. Your sound card would be the pre. You could easily wire in a pot to control volume, but straight from the sound card works best, and a decent volume control would cost as much as the amp. I will be back in FL Tuesday, and caught up on Wednesday. If you want I will be available to Polkies to help out with the mod. I am using mine to power some custom monitors with Polk woofers, and morel tweeters. Work very good. It goes louder then you would ever want to listen to for any length of time. I even drove my RTA15rdo's with it. Bass slam wasn't there with the 4 woofers, but it did better than I expected.
    Ben
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited May 2008
    This little amp sounded pretty good with the Pair of RTA 8 TL's I picked up. I actually liked the mid bass clarity this combo offered. No real deep bass but more than you would expect for such a modest outlay of $.
    Scott
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • ben62670
    edited May 2008
    Oops
    Ben
  • MillerLiteScott
    edited May 2008
    No amps coming my way that I know of.
  • ben62670
    edited May 2008
    Sorry. Wrong Scott:o
    Ben
  • ELSock
    ELSock Posts: 42
    edited May 2008
    if i picked up a couple of these would someone mod them for me? as easy as it probably is, i'm about as delicate as a rhino... so the help would be greatly appreciated.
    Display - Sony 60a2000
    AVR - Pioneer Elite 81TXV
    Mains - PolkAudio RM50Ts
    Center - Polk VM20
    Surrounds - Polk RM8's
    Rear Surr - Polk RM8's
    Sub - Polk DSW600 Pro
    Blu-Ray & DVD - PS3
    HDDVD - Extinct
    Games - Wii, Xbox360, PS3
  • ben62670
    edited May 2008
    Where do you live? I have modded 3 of these, and helped a few others. If you want to send them to me I can do the mods for you.
    Ben
    Ben
  • MillerLiteScott
    edited May 2008
    The mods are very easy.
  • ben62670
    edited May 2008
    If I remember when I get home I'll post some pics on where to attach the input wires to the main board. You can bypass a couple extra components on the main board to get the bass to go a little deeper, and clean it up very nicely in the mids, and highs.
    Ben
  • ELSock
    ELSock Posts: 42
    edited May 2008
    i appreciate the help, and i will most likely look into this very very soon.
    and for the record, i live in Ma.
    Center - Polk VM20
    Blu-Ray & DVD - PS3
    HDDVD - Extinct
    edited May 2008
    My two came tonight. Definitely worth ~$20 each (w/shipping-tax).
    The receiver board removal took all of 2 minutes each. Couldn't be easier really.
    Not overly impressed with the sound, but they can push a pair of Mon 7B pretty loud and for their intended purpose (pushing deck speakers and/or my computer rig), they will more than suffice and for the cost, it is an absolute steal.
    Oddly, the balance adjustment is backwards on both amps. They are a little noisy too. Hearing slight buzz through one or both channels on each amp. With the one I'm listening to now, the buzz seems to be diminishing the longer I have it on though.
  • MillerLiteScott
    edited May 2008
    Mine does not have any buzz and I just put the speaker wire into the opposite speaker output to correct the Left/Right issue. Besides it was only $15.
    Scott
  • ben62670
    edited May 2008
    1.) Remove the daughter board.
    2.) On the front board with the knobs remove the wires that lead to the inputs.
    3.) Remove the wires that run from the front board to the main board.
    4.) cut the wires from the RCA jacks near the front panel connector.
    5.) Locate the input wires on the main board. They should be L G R. They are on the right side of the group of wires.
    6.) Tie the input wires from the RCA's directly to the input wires on the main board.
    This mod bypasses all the knobs, op-amps, resistors, and low quality caps that kill the SQ on these little amps. You will have no volume control with this mod. Your source will need variable outs. Such as an Ipod, computer, or a CD player with variable outs.
    Ben
  • ben62670
    edited May 2008
    billbillw wrote: »
    You can loosen, and rotate the toridal transformer till the buzz goes away;)
    Ben
    edited May 2008
    ben62670 wrote: »
    Actually, most, if not all the buzz is gone in the one that I am listening to this evening. I'll probably use that one as is for a few weeks, then dig into it further to do some mods. For the one that I'm going to use on my deck, I will leave it stock because I'll need the volume control out there. Its hard to be critical of sound in that type of environment anyway.
  • pmlewis
    pmlewis Posts: 100
    edited May 2008
    I just got mine yesterday. The mod was very quick and easy. The hardest part was getting the feet off the case. I have not had time to put it to use yet but I have one question. How come we can use the outputs as inputs without switching around any cables for the RCA outs? I am not very well versed on amp design/theory and was just wondering why it worked.
    edited May 2008
    pmlewis wrote: »
    Because the original wireless input and the line out shared a common trace on the tone board. Once the wireless board's signal is removed, the line out feeds back through the tone board just like the wireless board's input did.
    edited May 2008
    ben62670 wrote: »
    I had an idea after pmlewis asked about the wiring that allows us to use the line out for input.
    I wanted to bypass the tone circuit, but I didn't want it to be permanent.
    Why not hook the input wires that lead to the main board to the spot where the receiver board was hooked. These plugs all have the same pin diameter and they can be removed from the their plug and rearranged however you like. So this is what I did.
    I took the three wires that corresponded to the L/G/R feed out of the larger plug. This can be done easily by using a small pin or paperclip to press on the retaining clip and easily pull them out of the plug.
    Next, I took the spare jumper wire that came off the receiver board and removed one of the plug ends. I re-inserted the 3 pins into the empty plug and then inserted it into the spot where the receiver used to plug in. Since the input and line out shared a common trace, this effectively acts as a jumper to bypass the tone controls, volume controls, etc. No cutting, no soldering, no taping. Oh yeah. I also took the sleeve off of the spare wire and put it onto the input wires to make things look cleaner.
    All done in about 10 minutes. Taking the tone control out removed any hum/buzz that was coming through the amp. Something in that circuit must have been picking up the transformer's magnetic field and turning it into ripple in the output.
    edited May 2008
    It should be noted that in this configuration (or any that bypasses the entire tone board), you are loosing a bit of overall gain. There is an opamp on the board that is being bypassed. Without that, I don't think an Ipod has enough output to really drive this amp to full power. A computer sound card might to better, but I haven't fully tested that setup yet.
  • Face
    Face Posts: 14,340
    edited May 2008
    I agree. After bypassing the tone board, if I use my PDA as a source, the amp is hardly loud at all.
  • ben62670
    edited May 2008
    I have been driving mine with an onboard sound card, and it has enough juice to drive it. I am curious if having it still hooked to the front panel has any adverse effects to sound level, and SQ even though the signal is not passing through it is still going to the board. My PDA was weak as well.
    Ben
    Ben
  • madmax
    edited May 2008
    Face wrote: »
    I didn't notice much difference. Must be something to do with impedances or something.
    madmax
    edited May 2008
    ben62670 wrote: »
    Ben
    I actually tried it using a set of pins to link the two plugs together versus having them hooked directly to the tone board. It sounded exactly the same. I ended up going with the arrangement in the photo because I trusted the connectors on the tone board more than a set of rigged up pins cut from a paper-clip :D
  • ben62670
    edited May 2008
    billbillw wrote: »
    :) Cool it wasn't a derogatory question, but something I was truly curious about. Thanks Bill
    Ben
    Ben
    edited May 2008
    ben62670 wrote: »
    Ben
    I didn't think it was derogatory. I was just letting you know I tried both ways and couldn't hear a difference. I was curious too. I still think I want to explore using part of the tone board and perhaps finding a way to bypass the tone controls and just keeping the balance and volume, but improving the quality of them. RadioShack sells a volume pot for about $4 that is supposed to be quite bit better than the stock one. I've got a slew of caps and opamps laying around too, so I might be able to make upgrades without spending much at all.
    The reason I'd like to keep volume control is if I decide to use an external DAC running from the optical output on my motherboard versus having an external high end sound card.
