Whats the difference between carver Ms and PMs
fbm211
fbm211 Posts: 1,488
edited May 2008 in Electronics
Anyone know about the carver PM-1.5 amp and the carver PM-1200 amp??They look alike and have same power output but I didnt get any more info.Do any of you know?And are they common ground? Compatable with SDA2Bs?
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
    F1nut Posts: 51,777
    edited May 2008
    They are both pro amps, keep looking.
    treitz3 Posts: 19,992
    edited May 2008
    Amen.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited May 2008
    I was told by Mylinda that the PM1.5 and the M1.5 were the same amp, just a fan on the pro and different hookups. However, I'd still go with the consumer model, silence is golden.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • zingo
    zingo Posts: 11,258
    edited May 2008
    I have the PM1201 and it is a pro amp. You can use it with your SDAs because it is common ground and it has pretty good sound quality for a pro amp. The fans can be an issue as mentioned, but I modded mine with a thermal switch so they don't turn on unless it gets real hot, which means they don't really turn on.
