SRS 2.3tl Tweeter problems
hangon
I pin pointed the bad tweeters, removed them all and check the Ohlms, (3) were open circuits. I then installed the (3) good Tweeters on one speaker, Loud sound from the Top Tweeter, Nothing from the Center Tweeter and Soft sound from the Bottom Tweeter. I used a paper towel roll placed over them to listen.
This is the same for Both Speakers. Do you think I need to rebuild the Crossover? Any information on this, or how to test? Or is this normal?
Thank you for any help or suggestions.
HT Theater
SRS-SDA 2.3tl RDO's
Custom Center made out of a RTA15tl
Pioneer Elite SC-25 Receiver
CineNova Grande 5 channel Amp
Klipsch KA-1000-THX Sub Amp
(2)Klipsch KW-120-THX Subs
Basement System
SRS-SDA 1.2 upgraded Xover
ADCOM GFA 5500
ADCOM GFA 5503
Yahama P7000S Pro Audio Amp
dbx 120x-ds Sub-harmonic Synthesizer
2-JBL 4645C Subs
1-Paradigm SW2200 Sub
Klipsch Reference in wall's
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
Post edited by hangon on
Start swapping stuff and see if the problem moves with the tweets or stays with the location.
Be aware that those 3 tweeters all have different crossover points, so you will get different sound from each one. On my 2.3tl the top one seems to carry most of the highs and therefore is "louder".
A crossover rebuild would be a good project regardless.Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about. -
I am wondering if Polk just sells the Tweeter Coils and domes for the sl3000? Has this been done before?
Is there any Pic's of the new RDO's? I am wondering if they look the same as the sl3000's.HT Theater
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
Klipsch Reference in wall's -
No, Polk doesn't sell anything related to the SL3000, not even the SL3000.
As you can see, they don't look like the SL3000, nor do they sound like them either and that's a good thing.Political Correctness'.........defined
President of Club Polk -
The RD0's that you want are RD0198-1's, They are $48 each from Polk Customer Service (make sure you tell them that you are in Club Polk)
Here they are:
Nice Speakers, mine are in good condition except the Tweeters (getting replacements from polk) are bad. How do I go about rebuilding my crossovers. I know that they have been cranked up to the max.HT Theater
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
I did a speaker compare last night with my Rti12's and the SRS-SDA 2.3tl's. I have 4 bad Tweeters in the 2.3tl's and they still out perform the Rti12's hands down. The sound is amazing, I have never heard such an awesome speaker before. I want to thank all the Polk members helping me with new Tweeter decisions upgrading them to the RDO's. My next goal is to upgrade the Crossovers.HT Theater
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
A wise choice. Make sure you let the new tweeters burn in for 24-48 hours before actually sitting down for a serious listen.Political Correctness'.........defined
I received my new RDO's today, installed them and I am getting awesome sound from all the tweeters. The old sl3000 were so bad they where barely producing any sound from them, so my crossovers are not defective. Thank you for all you help from the members of this forum. I am done posting here...HT Theater
SRS-SDA 2.3tl RDO's
Basement System
ADCOM GFA 5500
ADCOM GFA 5503
2-JBL 4645C Subs
