Ambience Tweeters
Early B.
Early B. Posts: 7,900
edited April 2008 in Speakers
I purchased a pair of ambience tweeters from VMPS and they arrived yesterday. Heres' the link: http://www.audiocircle.com/circles/index.php?topic=51181.0
The spiral ribbon tweeters are designed to face backwards and can be used with any speaker brand. The benefit of ambience speakers is well known and plenty of high end speaker manufacturers use them.
Here's my $0.02: The ambience tweeters add a bit more presence in the highs with a longer decay. There's a little more sizzle in the cymbals, and as the name implies, a bit of an ambient sound. It's a nice tweak. Of course, like most tweaks the difference is a subtle one, but I could tell the difference immediately.
I currently have my ambience tweeters sitting on top of my speakers. Of course, that's not ideal, but I dare to be different. VMPS suggests mounting them on the back of your speaker using double sided tape.
Pics are below. Yeah, I know, they're dusty, but don't nag me about it...
"God grooves with tubes."
Post edited by Early B. on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2008
    Extra tweeters, extra subs - you get your hearing checked lately? ;)
  • Midnite Mick
    Midnite Mick Posts: 1,591
    edited April 2008
    Not enough drivers in his mains I guess:)
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited April 2008
    I tried similar add on tweeters years ago. I liked them at first, then tired of them.
    I don't see any type of level control on these? I don't see how they would work with all speakers, considering the different sensitivities of various speakers.
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    Do you work for Machina Dynamica?
  • RuSsMaN
    edited April 2008
    Maybe he just needs a half dozen of those HSU mid-bass modules?
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited April 2008
    My VS VR4 Jr.s have them. I keep them dialed in at a subtle level 3. I like the effect.It seems to flesh out a more 3-D image.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • Early B.
    edited April 2008
    WilliamM2 wrote: »
    No level control, although you can partially cover the tweeter with foam, if you want, but it ain't necessary. They're 20 ohms, so they should work with any speaker.
  • Early B.
    edited April 2008
    RuSsMaN wrote: »
    Yep, and once I get 5,324 more pieces of audio gear, I'll have one-third of what you've got crammed in your closets.;)
  • RuSsMaN
    edited April 2008
    Closets are full of cables and tubes, tubes mostly. The rest of the gear is in the garage, and pickings are nearing the 'slim' status in short order.
    Cheers,
    Russ
  • unc2701
    unc2701 Posts: 3,587
    edited April 2008
    Hmmmm. Rear firing speakers for added ambiance... where have I heard that before?
    I know! Bose!
    Backburner:Krell KAV-300i
  • Systems
    Systems Posts: 14,873
    edited April 2008
    unc2701 wrote: »
    I know! Bose!
    A few years back Snell also had switchable rear firing tweeters on some models.IIRC the rear tweet only worked from 10k and above.
    Testing
    Testing
    Testing
  • dorokusai
    edited April 2008
    A loudspeaker designed around the idea is one thing, this is another. DefTech uses it pretty effectively as well but they aren't at Von Schweikert's level.
  • Systems
    edited April 2008
    dorokusai wrote: »
    A loudspeaker designed DefTech uses it pretty effectively as well but they aren't at Von Schweikert's level.
    The big Def Techs are bipolar designs so their rear output is full range not just the treble.
    Testing
    Testing
    Testing
  • dorokusai
    edited April 2008
    I'm aware, just making a blanket statement about rear firing drivers of an overall design. I'll try and be exact next time.
  • Early B.
    edited April 2008
    dorokusai wrote: »
    Well, Brian at VMPS has been designing excellent speakers for over 30 years, so he probably knows what he's doing. In fact, some of the earlier VMPS designs had ambience tweeters.
  • unc2701
    edited April 2008
    I think of ambiance tweeters as the opposite of treating your room.
  • dorokusai
    edited April 2008
    Early B. wrote: »
    I not concerned with that fact, or if his name was actually Yoda. Not everything is a winner. Why don't they use them now?
    heiney9 Posts: 25,419
    edited April 2008
    I will say since listening to SDA's again it's amazing how much delay, echo, ambiance many popular recordings use. The feel is to get a "live" room and make it seem like these are natural settings when in fact it's a very small, dead recording studio using digital effects.
    Some of it is over processed and the delay and ambiance is way over the top & some of it is subtle and I personally never noticed it on non-SDA speakers as much if at all. When it's done correctly at the recoding level it really adds something to the recordings.
    I still prefer recordings where the natural ambiance of the recording space is captured by multiple microphones rather than to have it "recreated" by digital effects. One of my favorite acoustic recordings is bootleg show by Sheryl Crow called the Trinity Church Sessions. Recorded with a minimal amount of equipment live in a church. It captures the the recording space very well and is outstanding quality.
    edited April 2008
    unc2701 wrote: »
    I know! Bose!
    I get the joke :p
    My brother has a pair of Mirage OM7's which they have patented the name "omnipolar" and they have a rear firing tweeter. They are somewhat of an acquired taste speaker. The center image never quite settles in the center and the other instruments sort of float around without relaying a specific orientation on the soundstage.
    They are very nice sounding speakers and the traits I mention are subtle. They work especially well in unconventional spaces where optimum placement isn't an option. They have great bass and very good presence just a bit unconventional on some types of recordings if you are used to a rock solid center image.
    P.s. Obviously not anything like Blose. They are actually a nicely civilized speaker
  • Early B.
    edited April 2008
    dorokusai wrote: »
    VMPS is using ambience tweeters now. They have begun to include them on most of their floorstanding speakers. Read the first post of the link I provided.
    F1nut Posts: 51,700
    edited April 2008
    heiney9 wrote: »
    That sums up my thoughts of MBL speakers, exactly. Kind of a wow factor at first, but just not natural in the end.
  • pearsall001
    pearsall001 Posts: 5,246
    edited April 2008
    Very interesting to say the least EB. I'm glad they're working out for you. I've read about other types of ambience speakers & was intrigued. I just never pulled the trigger on any. Fill us in later after they've been up & running for a while.
  • SKsolutions
    SKsolutions Posts: 1,820
    edited April 2008
    Looks like pest control.
    Wonder if it's effective.
    Guess not. . . , he keeps logging in. .
    -Ignorance is strength -
