FS: DefTech Sub, DefTech Towers, Boston Center
RuSsMaN
RuSsMaN Posts: 17,986
Boston VR-MC Center Channel
Oustanding condition. Comestically and operationally flawless. 15-150 Watts, 5 1/4 bass unit, 5 1/4 passive radiator, 1" dome tweeter with AMD. Weighs 14 lbs. HXWXD = 6 1/4 X 19 1/2 X 6 3/4
$220 shipped, lower 48
Definitive Technology Powerfield Subwoofer
Another spotless peice of gear. Strong, solid bass response in small to medium sized rooms.
Compact high-density monocoque medite enclosure with small footprint for easy placement.
Stiff, mineral-filled 8" Polypropylene cone with durable, long-excursion surround for fast action.
Huge magnet structure.
Frequency Response: 21-150 Hz.
250 Watt built in high power amplifier.
Signal Sensing Auto ON/OFF Circuitry.
Low Pass Crossover: 24 dB/octave continuously variable (40 —100 Hz), plus Unfiltered setting option
Speaker Level High Pass Crossover: 6 dB/octave at 80Hz.
Low-Level Inputs: Gold plated RCA left, right and direct LFE in.
Speaker Level Inputs: 5 way gold plated binding posts left and right channel.
Speaker Level Outputs: 5 way gold plated binding posts left and right channel.
Finish: Designer grade black ash
12-1/2" H x 9-1/2" W x 15-1/4" D
$150 shipped, lower 48.
I also have some DefTech 7006 towers, local sale only - $800. Killer small, HEAVY floorstander. 4.5" midwoof and 1" dome tweeter on front AND rear. Powered 8" Supercube woofer with twin 8" passive radiators. There isn't a cleaner pair on the planet.
Pictures to follow later tonight or tomorrow.
Cheers,
Russ
Post edited by RuSsMaN on
