Lsi15 internal crossover blew
foxyss
foxyss Posts: 5
edited April 2008 in Speakers
It took me forever to figure out why I wasn't getting the tweeter to work with my Lsi15. I checked all the connections, the amps, the cables... Hooked up my Rti10's that I have for Rears and the tweets work fine. I unscrewed the tweet on the 15 and hooked up the cables directly to it and it works fine. :rolleyes: I also checked the binding post and unscrewed it to make sure everything was still connected properly- no problems there. The wierdest thing is that both tweeters went out at the same time last night on both of my 15's. I hooked them back up today and now one of them works. :confused:
So basically my question is, is it possible to order new crossovers for the Lsi's? Also, does polk have local service centers? (I live in Seattle)
I find it wierd that the crossover would be the first thing to go. I wasn't even cranking them that hard. Anyone ever had this problem?
Post edited by foxyss on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited April 2008
    Sounds like a loose connection/solder joint, since after messing with the wiring, one side now works. You obviously aren't afraid to explore, so I would look into all connections carefully before laying out $$$ for parts.
    Polk will ask for return of parts for repair if under warranty.
    F1nut Posts: 51,700
    edited April 2008
    I doubt the problem is your crossovers. More than likely, your AVR clipped and took out the tweeters. Why one works now, I'm not sure. Anyway, swap the working tweeter for the non-working one. If the tweeter works, you know one have one bad tweeter and not a crossover problem.
  • SlowcarIX
    SlowcarIX Posts: 887
    edited April 2008
    you got one of these at home?
    my 7.(1x4) HT setup
    TV - Mitsubishi WD-65734
    AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
    Front - Emerald Physics CS2
    Center - JTR Triple 12LF
    Surround L/R / Back - Polk RTi4 / Polk FXi A4
    Sub - 4 X Hsu ULS15 playing nearfield
    DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
    Belkin PURE AV PF60 / UPS
    Buttkicker
    http://www.polkaudio.com/forums/showthread.php?t=60612
  • foxyss
    foxyss Posts: 5
    edited April 2008
    SlowcarIX wrote: »
    Yeah, I have one. What do you suggest?
    I know the tweeters are good. I looks like all the solder joints are good as well. :confused:
  • ben62670
    ben62670 Posts: 15,969
    edited April 2008
    Test across the speaker terminals for resistance.
    Ben
  • unc2701
    unc2701 Posts: 3,587
    edited April 2008
    foxyss wrote: »
    Don't do that again. Full range signals will kill most tweeters VERY quickly.
    Backburner:Krell KAV-300i
  • foxyss
    foxyss Posts: 5
    edited April 2008
    I tested the tweeter terminals and got 5ohms for both sets of speakers (left and right).
  • McLoki
    McLoki Posts: 5,231
    edited April 2008
    Don't know if having an LSi15 crossover schematic will help you or not, but thought I would offer this up....
    Michael
    BTW - LSi series is all the way at the bottom of the thread....
