Peerless and SDA2a's?
NJPOLKER
What would happen if I put my spare Peerless tweeters in my 2a's? The x-overs have been upgraded using exact values (Solens and Mills) on all caps and resistors.
I don't want to get into a tweeter debate just wondering if it could be a bad thing for some reason. I screwed up enough today.
Drew
Drew
Post edited by NJPOLKER on
IMO, it wouldn't be that difficult.
What tweeters do your SDA's have, SL2000's?
Compare the HF circuit of say a SL2000 Monitor 7 and a Peerless Monitor 7, and you'll know what changes need to be made to your SDA crossover.
Will it work? It should. Will it sound good, who knows?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I have RDO-194's in them and the other things sitting around. I am kinda curious if I can run the Peerless with out changes to the x-over. I like the Peerless tweeters. I know they are not a perfect fit but I can handle that.
I don't believe the crossovers are the same. The capacitors may be the same, but I believe the resistor(s) is different."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
yeh the tweeters resistors need will likley need changing to match the impedance/spl output to the woofer.ELECTRONICS
arcam cd93
linn wakonda
MC2 MC450
Teac ud h01 DAC
SPEAKERS
Tannoy DC6 t se . -
Well I went ahead and tried the Peerless tweeters in my SDA2a's and I must say they sound great. I am surprised just how clear and detailed they are, maybe I should not be surprised because I like them in the Monitor 10's. I will listen to them for a few days before hooking my SRSII's back up but am impressed so far.
To whom this concerns: I am not interested in a tweeter debate here or anything you have to say. Get it!! Yeah I got your private message and will ignore it and you and please do not send ma another private message.
