Used Marantz or New Emotiva/Dayton monoblock?
Hi folks,
I need a cheap monoblock amp (no more than $150) to power my passive sub (an NHT SW2), and I'm trying to decide between a used Marantz MA-500 and a new Dayton APA150 (which appears to be identical or similar to the discontinued Emotiva BPA-1). The Marantz is 125W into 8 Ohms and the Dayton (when bridged) is 150W into 8 Ohms, but both seem powerful enough to power the sub. They are both about the same price, so it's just a matter of which will sound better. Is monoblock preferable to a bridged amp? Anyone listened to both? Have any thoughts that could help with the decision? Or any thoughts on other subs I should look into? Thanks.
Post edited by roscoeiii on
  • engtaz
    engtaz Posts: 7,672
    edited April 2008
    Try the WTB section you will get more hits.
    engtaz
    engtaz
  • Early B.
    Early B. Posts: 7,900
    edited April 2008
    Can't go wrong with a Marantz MA-500. Marantz makes a nice monoblock. I haven't heard the Emotiva or the Dayton.
    "God grooves with tubes."
