surround back or surround
ns4433
ns4433 Posts: 16
hey guys quick question here. might seem simple but i just wanted clarification. i have a pioneer 770 watt reciever that is 7.1 . i am only using 5.1 but my question ius do i hook up the two rear speakers to surround(s) or surround back(sb)? thanks for the help
Post edited by ns4433 on
  • zingo
    zingo Posts: 11,258
    edited April 2008
    Hmmm...good question. I would do the back. On my pre/pro, the back is designed for regular speakers and the side surrounds are designed for di/bipolls. I feel that either of them would work if you had space constraints, but try the backs.
  • ntculenuff
    ntculenuff Posts: 1,146
    edited April 2008
    if i remember correctly on pioneer you use the surround hook up if only using 5.1
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • engtaz
    engtaz Posts: 7,669
    edited April 2008
    Is it the Pioneer VSX 1016TXV-K 7.1? If so zingo is correct with sourround back. Di/Bipolls like the FX series can be used as back and or sides. I prefer them for back. Most material is not in 7.1. SACD and ALL Stereo use the feature the most.
    Hope that helps
    engtaz
  • danger boy
    danger boy Posts: 15,722
    edited April 2008
    ns4433 wrote: »
    that would be 110 watts per channel X 7 = 770 watts total.
    if you had a 770 wpc receiver... it would be the size of a small fridge :eek: ;)
    welcome ns4433
    PolkFest 2012, who's going>?
  • zingo
    zingo Posts: 11,258
    edited April 2008
    danger boy wrote: »
    It would look something like this at 92lbs, 20" deep, and a foot tall:
  • engtaz
    engtaz Posts: 7,669
    edited April 2008
    LOL
    engtaz
    engtaz
  • ns4433
    ns4433 Posts: 16
    edited April 2008
    i think everyone knew what i meant, i guess when you spend all day on the polk forum the only thing that excites you is trying to make people sound like newbie's. anyway thanks to the people with the intelligent responses. help is what i was seeking not smart guy remarks. its the model: VSX-917V-K by the way for anyone trying to help me which i appreciate
  • polrbehr
    polrbehr Posts: 2,842
    edited April 2008
    ns4433 wrote: »
    Chill, my friend ... db meant no harm, I'm sure (notice the wink? Not to mention the "welcome ns4433").
    By the way, what brand/type of speakers are you running?
    Welcome to Polk, too.
  • zingo
    zingo Posts: 11,258
    edited April 2008
    ns4433, there's a bit of a system around here is what we're saying. It took me a while to learn it, as did a lot of people. It's not that he was trying to offend you, but the mass marketing for electronics isn't always accurate and some times we want people who are new to the forum to start off on the right foot; open their eyes as it were. :eek:
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2008
    I have an Elite and the answer is absolutely positively for 5.1 hook up the surrounds. Surround back only for 7.1. The surround backs can sometimes be used for bi-amping front speakers on Pioneer units. My VSX-912tx allows me to use the surround backs for bi-amping or for a another sub. Read the manual and it will tell you what that model is capable of and how to hook it up. There are settings in the menu to change the surround back configuration.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • engtaz
    engtaz Posts: 7,669
    edited April 2008
    Answers I gave in post #4 still goes.
    engtaz
    engtaz
  • John K.
    John K. Posts: 822
    edited April 2008
    4433, there's no option available in that situation: the connection has to be made to the surround(i.e., side surround)terminals rather than the back surround terminals. The back surround terminals are there to drive separate back surround speakers when they're present in a 7.1 setup in addition to the side surround speakers. If the side surround speakers would be set "no", there would be no signals sent to the back surround terminals and any speakers connected to them would remain silent.
    Since you'll be using only side surround speakers in a 5.1 setup, it'd be a good idea to position them a little(say 2')farther back than directly to the sides of the listening position, to lend a little more "back" effect in the absence of actual back surround speakers.
    F1nut Posts: 51,781
    edited April 2008
    Hey Johnny, someone said yesterday that you were due for a post and what do know...here you are.
  • ns4433
    ns4433 Posts: 16
    edited April 2008
    thanks for the input guys. helped me a lot. reciever is up and running perfect
