Tape Deck Recommendation
mightymouse
mightymouse Posts: 254
edited April 2008 in Electronics
Okay, I know not many people use tapes anymore. But I still have a ton of tapes lying around that I would like to listen to again.
So of the current crop of tape decks that are still made, which ones do you guys recommend.
Are vintage tape decks even worth it anymore? I am not too keen on restoration.
Post edited by mightymouse on
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2008
    Seriously? Do they have any information on the JFK Assasination or Whitewater? Get rid of them.
    I thought it would be a cool idea too, awhile ago, and picked up a HOT Nakamichi RX-505. It wasn't, tapes suck.
    If you are overwhelmed to relive this portion of your life for some reason, look for a Sony ES deck since they are pretty common, cheap and the 3 head units are decent for sound reproduction.
    F1nut Posts: 51,786
    edited April 2008
    Interestingly enough, most pre amps still offer a tape selector despite tape decks fall from grace.
    I'm not up on what the market has in new decks these days, but the vintage Sony ES 3 head units were very good, while the king of decks was and probably still is the Nakamichi Dragon.
    Good luck in your pursuit.
    billbillw Posts: 7,560
    edited April 2008
    Look for a late model Sony ES single deck with Dolby S. They go pretty cheap on Ebay.
    Be prepared for disappointment though. I picked up a Sony ES a couple years back. Played back a handful of tapes. They all sounded like garbage, so that's where they went for good, in the trash.
    The deck does make wonderful recordings though. The late models with Dolby S do a fantastic job if matched with a good metal or CRO2 tape.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2008
    Jesse, you feeling ok? ;)
  • Face
    Face Posts: 14,340
    edited April 2008
    Check your local thrift stores. My local shops usually have a stack of tape decks.
    mhardy6647 Posts: 35,040
    edited April 2008
    what kind of tape are you talking about?
    This kind?
    or this kind?
  • mightymouse
    edited April 2008
    Thanks guys for the recommendations. The reason why I want to get a tape deck is because my shelf system, which has 2 cassette wells, is falling to pieces. I don't want to throw out all my old tapes, and it would be really expensive to replace them with CD's or whatever newer formats that will come along.
    About the Sony ES tape decks, do tape decks deteriorate over time? I read somewhere that the read head needs to be recalibrated after a while.
    What do you guys think of this one? Since it's still in production and new, I think I may have less hassle with it.
    http://www.amazon.com/Sony-TCWE475-Cassette-Player-Recorder/dp/B00005T408/ref=pd_bbs_3?ie=UTF8&s=electronics&qid=1207582773&sr=8-3
    mhardy6647, I think my tapes come in retangular boxes and I think they fit into that tape deck in that second picture.:D
  • cmy330go
    cmy330go Posts: 2,341
    edited April 2008
    dorokusai wrote: »
    I don't know why but that sentence just killed me!!:D
    Anyway. Unless you are willing to clean and tuneup an oldie the Sony probably is your best bet. I too tried out some old tapes not long ago, and just gave up. It was hard for me to believe that I ever thought they sounded good.
    I did however recently hear an old system recently that sounded really good with tape, but the key to the good sound was the EQ. If you disabled the EQ it just went to complete crap. If you do end up with a tape deck it might be worth it to snag an old EQ to run in-line with just the deck. At least then you can make up for some of the weaknesses of the format.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • bobman1235
    bobman1235 Posts: 10,822
    edited April 2008
    I bought a tape deck from someone here years ago (I think it was Doro) thinking I'd revive my tape collection. Even with a decent deck they still just don't sound good. I keep it sitting on the shelf cuz it looks kinda cool but don't think I've turned it on since I first got it.
  • polkatese
    polkatese Posts: 6,767
    edited April 2008
    It's all about sentimental value, nothing more, nothing else (for me). I have tons of collection from the 80s that they are still in great conditions, so it was fun. Recording quality wise is not that great, but they are listenable.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    edited April 2008
    I wouldn't worry about the heads going bad with normal use. AFIK, the only thing that really goes bad are the rubber belts.
