Popcorn maker owners
opus
opus Posts: 1,252
edited March 2008 in The Clubhouse
Anybody own a popcorn maker here? I just bought one from a gas station going out of business.
I did a few test batches and not quite happy with the results.
What type of popcorn and oil do you use?
Do you add butter or flavoring?
What is your popcorn/oil ratio?
This is why the terrorists hate us, I know:D
Big problems in a big world
kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Post edited by opus on
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    Is it one of those big, square ones? Like popcorn cart sized?
  • opus
    opus Posts: 1,252
    edited March 2008
    dorokusai wrote: »
    Yep, just like ones that are in most bars, concession stands and convenience stores.
    Got the big yellow "popcorn" banner on it
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • nikolas812
    nikolas812 Posts: 2,915
    edited March 2008
    I hate popcorn.
  • opus
    opus Posts: 1,252
    edited March 2008
    nikolas812 wrote: »
    I hate popcorn.
    Duly noted ////
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • tx_polkhead
    tx_polkhead Posts: 248
    edited March 2008
    Jolly Time sells a 'All-in-one popcorn kit' with pre-measured pop corn, popping oil and butter-flavored salt in a two part sealed bag, the commercial popper instructions are:
    1 preheat 5 - 7 minutes
    2 cut open pouch and pour all ingredients at once
    3 when popping stops dump kettle immediately
    4 turn kettle switch off
    the container/pouch does not say what the ratio of kernels to goopy oily orange stuff but it looks like 4:1 kernels to butter like stuff. It does have a web link printed on the package www.jollytime.com
    yep, I dig popcorn, my latest kick is kettle corn, at a ratio of just less than 2:1 kernels to sugar, the stuff in like crack!
    Polk Audio RTA 12c's, Monitor 7c, Monitor 5JR+, SDA CRS+
  • chefdave
    chefdave Posts: 11
    edited March 2008
    Does all the parts work. i.e. the agitator in the kettle. Can it draw enough power from the circuit? Using a popcorn oil is usually the best way to go as they are formulated for the high heat. Follow the package directions on any popcorn. The oil should be hot before adding the popcorn. Be careful as the kettle can give you a nasty burn. Good Luck and enjoy your popper.
  • fazer
    fazer Posts: 9
    edited March 2008
    I use organic coconut oil when i make popcorn
    usually 3 tbls to 1/2 cup of kernels.
  • candyliquor35m
    candyliquor35m Posts: 2,267
    edited March 2008
    The bar I used to go to would add some tabasco/hot sauce to the oil. Tasted incredible especially with a beer handy to wash it down.
  • Gadabout
    Gadabout Posts: 1,072
    edited March 2008
    Doesn't everyone make popcorn that way?:D
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    edited March 2008
    chefdave wrote: »
    I would tend to listen to popcorn cart advice from someone named "Chefdave.
  • opus
    opus Posts: 1,252
    edited March 2008
    Good point;)
    I tried some basic oils from the store and some Redenbacher popping oil but they all lacked the buttery flavor of "bar" corn. I am heading to my local watering hole as soon as it opens with a empty oil container to do a little shopping. "Yea, give me two Coors Lights and a quart of Jolly popping oil":D
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
    heiney9 Posts: 25,432
    edited March 2008
    The Jolly Time kit is the best solution if you want that buttery, greasy taste you get from bar popcorn. You can't just use common grocery store oil in those machines and get the flavor you are looking for.
    My mouth is watering.
  • opus
    opus Posts: 1,252
    edited March 2008
    Thats 2 for JollyTime.
    Google here I come
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited March 2008
    What happened to just hitting the popcorn button on the microwave?
    :confused:
  • opus
    opus Posts: 1,252
    edited March 2008
    :confused:
    Dude, I'm just a brass pole away from having a killer basement:D
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • BaggedLancer
    edited March 2008
    opus wrote: »
    Gotcha beat, I already have the pole :D
  • dorokusai
    edited March 2008
    Yea, but you swinging on it in your "woman" suit doesn't really count for anything.
  • opus
    opus Posts: 1,252
    edited March 2008
    Wonder what Chefdave thinks about brass poles:D
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • mrbigbluelight
    edited March 2008
    opus wrote: »
    Well, here's some tape footage (from Chefdave's security system) that just may answer that:
    <object width="425" height="355"><param name="movie" value="http://www.youtube.com/v/Enw2wC3fi8w&hl=en"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/Enw2wC3fi8w&hl=en&quot; type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
    .....uhm ..... sorry, Chefdave ...... :o
  • chefdave
    chefdave Posts: 11
    edited March 2008
    In general I like brass poles...but it is all in where you put them!
  • wizzy
    wizzy Posts: 867
    edited March 2008
    Could be you have a newer model. You need one that uses Vacuum Tubes for that true movie theater popcorn taste.
