blown fuse?
eloplayspolo
eloplayspolo Posts: 1,117
edited March 2008 in Car Audio & Electronics
k so, amps are NOT turning on, checked remote wire... everything seems to be in place. all the wires look good.... i pulled out the fuse.... some of the plastic is melted/burnt.... but the fuse itself looks good..... what do u guys think?IMAGE_035.jpg
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Post edited by eloplayspolo on
  • exalted512
    exalted512 Posts: 10,734
    edited March 2008
    I think you need to switch to an ANL fuse holder and make sure its not next to anything that gets got in your engine compartment.
    -Cody
  • eloplayspolo
    edited March 2008
    yeah i know.... i need 20 bucks though :(!!!!!!! umm do u think the fuse is okay?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • exalted512
    edited March 2008
    Hard to tell from your blurry pic. But they can 'partially' blow and look fine, but limit your voltage to about 5V, which is not enough to turn on your amp.
    -Cody
  • exalted512
    edited March 2008
    Also, if youre not running big power, you can get away with the MINI ANL fuses, they can just be semi-hard to find sometimes.
    http://knukonceptz.com/productDetail.cfm?prodID=FH-44
    -Cody
  • eloplayspolo
    edited March 2008
    idk... 1100w rms big power? 2 mtx amps.... ummmm only way to test would be a meter right?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • exalted512
    edited March 2008
    1100w rms would be fine on a mini anl. Meter would be best, but I wouldnt use a burnt fuse.
    -Cody
  • HiPerf360
    HiPerf360 Posts: 436
    edited March 2008
    If you are asking these qustions I would just try a new one
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited March 2008
    exalted512 wrote: »
    -Cody
    Those are the exact ones that I am running. I just bought a few different fuses to have on hand. Came in handy this weekend as I ended up needing one for my sub amp. The things was not putting out power for a couple of weeks, finally had time to look into the issue.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
