Lsi15's and LsiC with Rti10 surrounds?
foxyss
foxyss Posts: 5
edited March 2008 in Speakers
Just wondering if it is okay to match the Lsi series fronts/center with Rti series surrounds? Or, would it be better to get Rti series all the way around? I really like the Lsi's and I'm thinking about getting some to complete the fronts but I want to make sure they will sound all right together. Any thoughts? :)
Post edited by foxyss on
  • john22614
    john22614 Posts: 214
    edited March 2008
    I really don't think it's that big of a deal unless you listen to a lot of 5 channel SACD music
    For the discreet and special effects sounds of HT, it doesn't matter that much. I listen to music in stereo and, because of space constraints, use my little Monitor cubes for HT surrounds and they blend in fine. Where timbre matching matters most is up front. I think your RTi's will work just fine.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • Gaara
    Gaara Posts: 2,415
    edited March 2008
    It is fine to mix and match on the surrounds. I used the LSiFxs in my Gallo setup and it sounded great, and have also heard RTi setups with cheap surrounds that sounded good to.
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    Don't lose sleep over it.
  • sb_caribou
    sb_caribou Posts: 32
    edited March 2008
    agreed. i've never used "matching" rear speakers because of the need for small and unobtrusive. may not be perfect, but haven't noticed any problems.
