3' RCA to RCA Audio Cables (HT130)
SPEAKER7
Just curious if these rca cables from AR is good enough quality to use for connecting amp/pre/cd player? Any thoughts?
Directional, balanced-line, oxygen-free copper cable with precision-machined, gold-plated connectors.
http://www.araccessories.com/pro/subcategory.asp?category=2
thanks,
dc.
thanks,
dc.
Post edited by SPEAKER7 on
Yes they are, depending on price, you may have other (possibly better) options.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
thanks,
I believe the 3' ft cable goes for $34.99cdn.
dc.:) -
So what does that mean to me, $12-$15 US per pair?
Cheers,
AR make some fine interconnects. I've been using there performance series for a while and can't complain.
Recently I tried a little experiment with some Radio Shack FusionAV interconnects. Their build quality is exceptional and makes my AR performance series cables look like the cheap interconnects you get when you buy a DVD or CD player. They also have external ferrite filters on the lines. Pricing is very competitive. I paid $24 for a 3 foot run. Check out the details here...Damn....8 lines...I've gotta put my sig on a diet now.... -
No complaints as I'm using their Ten Guage Master series Silver + copper stranded speaker wire !!
Polk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111 -
Stereophile just put a little paragraph about the AR HT130 in this months issue. They said it's "all the interconnect you'll ever need"
not too shabby for the price! I'd buy it in a heart beat after having Stereophile say that! They use STUPID amounts of expensive wire all the time!Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Thanks everyone for your feed back.......I will probably pick up a pair or two to hook up my up and long coming separate 2ch audio system which is still in the planning stages.
Russman........your price looks even better......$15-16 US.
dc.
