3' RCA to RCA Audio Cables (HT130)
SPEAKER7
SPEAKER7 Posts: 355
edited April 2003 in Electronics
Just curious if these rca cables from AR is good enough quality to use for connecting amp/pre/cd player? Any thoughts?
Directional, balanced-line, oxygen-free copper cable with precision-machined, gold-plated connectors.
http://www.araccessories.com/pro/subcategory.asp?category=2
thanks,
dc.
:confused::confused:
Post edited by SPEAKER7 on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2003
    Yes they are, depending on price, you may have other (possibly better) options.
    Cheers,
    Rooster
  • SPEAKER7
    SPEAKER7 Posts: 355
    edited April 2003
    thanks,
    I believe the 3' ft cable goes for $34.99cdn.
    dc.:)
  • RuSsMaN
    edited April 2003
    So what does that mean to me, $12-$15 US per pair?
    Cheers,
    Rooster
  • TonyPTX
    TonyPTX Posts: 545
    edited April 2003
    AR make some fine interconnects. I've been using there performance series for a while and can't complain.
    Recently I tried a little experiment with some Radio Shack FusionAV interconnects. Their build quality is exceptional and makes my AR performance series cables look like the cheap interconnects you get when you buy a DVD or CD player. They also have external ferrite filters on the lines. Pricing is very competitive. I paid $24 for a 3 foot run. Check out the details here...
    Damn....8 lines...I've gotta put my sig on a diet now....
  • begbie
    begbie Posts: 630
    edited April 2003
    No complaints as I'm using their Ten Guage Master series Silver + copper stranded speaker wire !! :D
    Polk Rt800i -Fronts
    Polk cs400i -Center
    Polk fx500i -side surrounds
    Polk rc60i -rear surrounds
    Onkyo TX-NR 1009 (9.2) receiver
    Velodyne cht12
    Polk psw111
  • tryrrthg
    tryrrthg Posts: 1,896
    edited April 2003
    Stereophile just put a little paragraph about the AR HT130 in this months issue. They said it's "all the interconnect you'll ever need"
    not too shabby for the price! I'd buy it in a heart beat after having Stereophile say that! They use STUPID amounts of expensive wire all the time!
  • SPEAKER7
    SPEAKER7 Posts: 355
    edited April 2003
    Thanks everyone for your feed back.......I will probably pick up a pair or two to hook up my up and long coming separate 2ch audio system which is still in the planning stages.
    Russman........your price looks even better......$15-16 US.
    dc.:lol:
