Switched or Unswitched ?
c4kaboom
I use an Onkyo receiver to run most of my speakers but have an Adcom GFA 555 running my main fronts. Can I plug my Adcom into the Onkyo so all I have to do is turn on the Onkyo to activate the Adcom's power ?
RTi 12's main
CSi5 Center
Monitor 70's Surrounds
PSW125 Sub
Onkyo 805
Fronts Adcom GFA 555 powered
I/C's from the wall of Circuit City
Wire by BlueJeans at $.65 per foot
CSi5 Center
PSW125 Sub
Onkyo 805
Post edited by c4kaboom on
What is the power limits on the receiver? If your amplifier is less wattage than your receiver allows, then yes!
I don't know if I'd recommend that, those auxiliary outlets on receivers aren't usually designed for high-amperage devices like amplifiers.If you will it, dude, it is no dream.
No you can't. The switched outlets on the back of recievers is usually limited to 100 to 150 watts.
You could use a device like this:
http://www.smarthomeusa.com/Shop/Smart-Energy/Smart-Strip/Item/SCG4/ -
No, that's not a smart idea.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I thought I might have a problem with wattage doing this. Thanks for the advice.RTi 12's main
CSi5 Center
PSW125 Sub
Onkyo 805
Wire by BlueJeans at $.65 per foot -
even though its no we appreciate your thanks
enjoy the gang. oh if your oinker has a 12v out you can likely rig something up.
RT1 -
Don't plug the amp into your Onkyo's switched outlet, you'll blow up the receiver's power supply (don't ask how I know, but its the reason why I no longer have my TX-SR500).polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Unless you want to smoke test that Onkyo I wouldnt do it !!!:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Deadof_knight wrote: »Unless you want to smoke test that Onkyo I wouldnt do it !!!
Oh yes you can easily smoke that Onkyo!
Smoking an Onkyo sounds like a bad idea, from any angle...
Haha, seriously though they must have little or no internal protection...polkaudio RT35 Bookshelves
Unless you have the upgrade bug, and a significant other;)Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I wouldn't simply due to the current start up needed for the amp. Adding that to the Onkyo is even greater current draw.[
smoke a doo:)bie,, plug the amp into the wallJC approves....he told me so. (F-1 nut)
