Switched or Unswitched ?
c4kaboom
c4kaboom Posts: 20
I use an Onkyo receiver to run most of my speakers but have an Adcom GFA 555 running my main fronts. Can I plug my Adcom into the Onkyo so all I have to do is turn on the Onkyo to activate the Adcom's power ?
RTi 12's main
CSi5 Center
Monitor 70's Surrounds
PSW125 Sub
Onkyo 805
Fronts Adcom GFA 555 powered
I/C's from the wall of Circuit City
Wire by BlueJeans at $.65 per foot
Post edited by c4kaboom on
  • zingo
    zingo Posts: 11,258
    edited March 2008
    What is the power limits on the receiver? If your amplifier is less wattage than your receiver allows, then yes!
  • bobman1235
    bobman1235 Posts: 10,822
    edited March 2008
    I don't know if I'd recommend that, those auxiliary outlets on receivers aren't usually designed for high-amperage devices like amplifiers.
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited March 2008
    No you can't. The switched outlets on the back of recievers is usually limited to 100 to 150 watts.
    You could use a device like this:
    http://www.smarthomeusa.com/Shop/Smart-Energy/Smart-Strip/Item/SCG4/
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    No, that's not a smart idea.
  • c4kaboom
    c4kaboom Posts: 20
    edited March 2008
    I thought I might have a problem with wattage doing this. Thanks for the advice.
    RTi 12's main
    CSi5 Center
    PSW125 Sub
    Onkyo 805
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2008
    even though its no we appreciate your thanks
    enjoy the gang. oh if your oinker has a 12v out you can likely rig something up.
    RT1
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2008
    Don't plug the amp into your Onkyo's switched outlet, you'll blow up the receiver's power supply (don't ask how I know, but its the reason why I no longer have my TX-SR500).
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Deadof_knight
    Deadof_knight Posts: 980
    edited March 2008
    Unless you want to smoke test that Onkyo I wouldnt do it !!!
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • Serendipity
    edited March 2008
    Oh yes you can easily smoke that Onkyo! :)
  • zingo
    zingo Posts: 11,258
    edited March 2008
    Smoking an Onkyo sounds like a bad idea, from any angle...
  • Serendipity
    edited March 2008
    zingo wrote: »
    Haha, seriously though they must have little or no internal protection...
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    zingo wrote: »
    Unless you have the upgrade bug, and a significant other;)
    Ben
  • vonnie123
    vonnie123 Posts: 326
    edited March 2008
    I wouldn't simply due to the current start up needed for the amp. Adding that to the Onkyo is even greater current draw.
  • george daniel
    george daniel Posts: 12,096
    edited March 2008
    zingo wrote: »
    smoke a doo:)bie,, plug the amp into the wall
