MIT Terminator 4
har_navalta
har_navalta Posts: 957
Anyone using these wire, let me know if this one will work
OK:confused: for SDA's.
    F1nut Posts: 51,703
    edited March 2003
    Har,
    Do you mean as the interconnect cable?
    Jesse
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited March 2003
    Using them on my CRS+ right now, and diggin' em.
    Cheers,
    Rooster
  • har_navalta
    edited March 2003
    No, someone selling it to me.
  • har_navalta
    edited March 2003
    These are the tips...
    F1nut Posts: 51,703
    edited March 2003
    Har,
    Yes, they will work. I have MIT Shotgun's all around and like Russ, I'm diggin' em!
    How much do they want?
    Jesse
    F1nut Posts: 51,703
    edited March 2003
    Har,
    Those are the ICONN tips. You screw on the ends, either banana or spades.
    Jesse
  • har_navalta
    edited March 2003
    $55 the guy need money immediately:confused:
    is it OK for that amount?
    I don't have idea how much for Original price for that...
    Har
    F1nut Posts: 51,703
    edited March 2003
    Har,
    You can check here.
    http://ecom3.aspre.net/cgi-bin/TheCableCompany.storefront/
    Click on speaker, then click a couple of pages until you come to MIT.
    Jesse
    F1nut Posts: 51,703
    edited March 2003
    Har,
    Also, here.
    http://cgi.audiogon.com/cgi-bin/srch_fs.pl
    Jesse
    EDIT: Har, does he have the screw on ends? If he doesn't, they are about $15.00 for a set of four and that would make the deal a bad one.
