WTB: Cheap Power Cord
uvaskeme
I'm looking for a cheap power cord for my Anthem MCA 30. I just got the amp used off Agon, but it didn't include the cord. The Anthem tech told me to get a 2 prong polarized one that is at least 14 gauge. I don't know much about power cords, but I really don't want to spend a lot on it. My max is probably no more than $75, but less is always better. If you have one, or if you know of a place that sells decent ones, please let me know. Thanks!
My Setup
Onkyo TX-SR805
Anthem MCA 30
Polk Audio LSi15
Polk Audio LSiC
Polk Audio FXi A4
Bic Acoustech H-100
Collecting Dust
Polk Audio RTi10
Polk Audio CSi5
Onkyo TX-SR805
Anthem MCA 30
Polk Audio LSi15
Polk Audio LSiC
Polk Audio FXi A4
Bic Acoustech H-100
Collecting Dust
Polk Audio RTi10
Polk Audio CSi5
Post edited by uvaskeme on
http://www.avhifi.com/xcart/product.php?productid=16505
PS Audio xStream Power Punch Power Cable
49.99 shipped. It has a removable ground pin so, in your case, if you ever wanted to use it with another component that utilizes the ground you'd be good to go. This place takes PayPal too. Don't get the 2-prong C7 though as that wouldn't fit the amp end.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
These are a little more $ - Shunyata Venom or PS Audio Prelude SC.
Oops-forgot the prices-Shunyata $99. PS Audio $135.
thanks for your help guys. i think ps audio might be the way to go. are the ps audio preludes any good (the non-sc version)? i can get a 1.5m used for $75. thanks.My Setup
Onkyo TX-SR805
Anthem MCA 30
Polk Audio LSi15
Polk Audio LSiC
Polk Audio FXi A4
Bic Acoustech H-100
Collecting Dust
Polk Audio RTi10
Polk Audio CSi5 -
They are all good. That Prelude sounds like a great deal for $75. Make sure it's IEC and not C7 as someone else mentioned.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I will be getting the 1.5m Preludes tomorrow. One question, though... are they polarized? The Anthem manual says to only use a "polarized alternating-current line plug (a plug having one blade wider than the other)." From the pictures on the PS Audio website, the blades look to be the same size.My Setup
Onkyo TX-SR805
Anthem MCA 30
Polk Audio LSi15
Polk Audio LSiC
Polk Audio FXi A4
Bic Acoustech H-100
Collecting Dust
Polk Audio RTi10
Polk Audio CSi5 -
Yes,they are.
Check out Signal Cable, very well reviewed on this and other forums. This one's cheaper than your price range and will do you right. Frank gives a 5% ClubPolk discount as well:
http://signalcable.com/magicpower.html
I have 3 power cords, the power extension, and 2 pairs of interconnects from him. Top quality build, great prices, sound awesome, and highly regarded so they sell quite well if you decide to pass it on. I wish I'd heard of him before I did my own DIY cables (but I like those too....)
EDIT: Actually this is a three-prong cord, but if you call Frank perhaps he'd do a 2-pronged beauty for you....Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
