Lsi15 - Best way to drive them...
Racker99
Racker99 Posts: 13
edited March 2008 in Speakers
In a recent reply I gave the story, but basically I was able to pick up a pair of brand new LSi15's in Cherry for around $660.
Now, before I hook them up in my theater room as the new left & right channels, I would like to know that my tuner will not cause harm to them by trying to run them with it.
I currently have a lower end Sherwood A/V receiver RD-7502. http://www.sherwoodusa.com/prod_rd7502.html Specs wise it indicates 100 Watts per Channel at 8 Ohms. Longer term I'm not opposed to upgrading this to a higher quality receiver, but am overall pretty happy with how it's working currently. Upstairs I currently have one of these receivers driving a pair of RTi8's and they sound great.
I realize that the LSi15's are 4 Ohm speakers, but don't know technically if they will still work with my current receiver, but not optimally, or by trying to drive them with this unit I will actually damage them in some way.
If I do need another amp, what is the cheapest 2 channel amp that will provide reasonable sound that might work?
Post edited by Racker99 on
  • dorokusai
    dorokusai Posts: 25,576
    edited March 2008
    You can certainly run them but I would stick with moderate listening levels and monitor the heat on the Sherwood. A seperate amplifier would be a huge benefit. Check out the Flea Market section for some options.
  • Face
    Face Posts: 14,340
    edited March 2008
    The "Analog Output", are those considered pre-amps?
  • Refefer
    Refefer Posts: 1,280
    edited March 2008
    They will technically work, but be prepared to not be impressed. The Lsi series loves power and needs to have an amp that can handle the impedance dips.
    Get yourself a used carver or adcom amp for around $250, and you should be good. Try to get at least 150 clean watts into them, and more if possible.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • Racker99
    Racker99 Posts: 13
    edited March 2008
    Given that the speakers are rated upto 250 watts / channel, will I be happy with an Amp that delivers 150 watts, or should I try to get something that does a full 250?
    I know that the watts alone don't mean better sound, but I've not dealt with power hungry speakers before.
    Also since the rest of my speakers will still be running at 100 watts / channel I don't want to make things sound unbalanced. Would that be an issue if I used 250 watts vs. 150?
  • Refefer
    edited March 2008
    Racker99 wrote: »
    It depends on how loud you play it. If you're going to play it at very loud levels, you don't want to risk overdriving the amp and possibly blowing everything.
    How big a room do you have? Will this be for home theater or just a damn good 2 channel? Honestly, 150 quality wpc from a high current amp should do most people just fine, so long as your not trying to set a sound level record.
    That said, you can never have too much juice on reserve: just asking for too much when you don't have it, or giving too much past its rating.
    Polk SDA-1B,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    Computer Rig
    Polk SDA CRS+,
  • Racker99
    Racker99 Posts: 13
    edited March 2008
    I'm planning to put the LSi15's into my theater room as my Left and Right Channels.
    Currently I have a Polk CS400 as my center and am using TC615's as my surround speakers. I also have a Sunfire 700 Sub.
    The room size is 14' x 23', so it's a pretty large theater room space. I'm using a Panasonic 100U projector with a 139" diagonal 16:9 screen.
  • hockeyboy
    hockeyboy Posts: 1,428
    edited March 2008
    You will never regret getting a more powerful amp. If you are going to spend the money just go a bit more and get something that will last you for a decade. My amp puts out 400 WPC at 4ohms and has never given me problems with too much power.
    Remember to get an amp that is actually rated at 4 ohms though. The majority of amps that say 100 watts are talking about at 8 ohms. If that same amp is also rated at 4 ohms it will push closer to 200.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • Racker99
    Racker99 Posts: 13
    edited March 2008
    I had had tried to check with Mark and local to see if I could find an Amp for a good deal - No word back from anyone so I was looking on sleazbay a bit.
    There was a Carver TFM-25 that was ending its auction today, I believe it was put up by a refurb shop so it should be in good working order. Could have gotten it for $350 or so, but they set a reserve at $395 so I had to bid up to hit the reserve. Final Cost is $395 + around $62 in shipping.
    Given that I was willing to pay up to around $400 locally with no shipping I don't feel like I got THAT bad of a deal. Hopefully no more than $100 over what it should have cost.
    Given that it'll deliver 350 Watts RMS per channel at 4 ohms I hope it'll drive my new LSi15's sufficiently, (but not over drive them.)
    Thoughts?
  • MikeCamp
    MikeCamp Posts: 12
    edited March 2008
    Yamaha RXV3300
    Polk LSI series - 15,C, and FX
    Infocus 4805
    Emotiva XPA-5 power amp
  • bbeacham
    bbeacham Posts: 141
    edited March 2008
    Racker99 wrote: »
    I have a Sunfire TGA-5400, which does 800W x 5 @ 4 ohm driving 4 LSi15s and an LSiC. So far all it has done is make the sound crystal clear and unstrained at the highest sound levels. More than once I have read that speakers are more easily damaged by clipping from an underpowered amp than from having to much power. Of course, as with anything I am sure there are instances where you can fry a speaker with to much power.
    However, even when I was driving these speakers with a Denon 3805 receiver (120w/ch), and, later, a Sony 7100ES receiver (175w/ch) they produced high sound levels and great sound. Its just that now they produce even better sound.
  • ohskigod
    ohskigod Posts: 6,505
    edited March 2008
    that Carver should do those 15's nicey nice. the sound difference between that and your sherwood is going to shock you a bit.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Racker99
    Racker99 Posts: 13
    edited March 2008
    I haven't received the Carver Amp yet, but I did finally receive my second speaker yesterday. I hooked the pair up to the Sherwood and was already amazed at how clear and nice they sounded. After a few songs however the speakers didn't quite sound as clear and I believe my Sherwood was starting to under drive them, so I turned everything off before any harm could occur.
    In looking at how to hook up my new amp when it arrives I was shocked to discover that the Sherwood receiver I purchased doesn't have Pre-outs for all channels. It only has a single pre-out for the subwoofer. However, it does have 'tape out'. My theory is that I can run the 'tape out' signal to the amp and all should be well with the world. For stereo music I'm 99.9% certain that this will work just fine. My concern exists for when I am watching a movie in 5.1 or 7.1 surround sound.
    Does anyone know or have any guess as to if the tape out stereo feed will be equivalent to what pre-outs for Left / Right channel would provide? Or will they be getting more of the signal than they should and end up providing an incorrect 5.1 / 7.1 listening experience?
    If I have to purchase a new A/V receiver which actually has pre-outs, I'll consider it, but I'm hoping I can correctly drive these new speakers without having to completely replace my whole home theater setup.
  • tcrossma
    tcrossma Posts: 1,301
    edited March 2008
    I could be wrong, but isn't a tape output a fixed-volume output?
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Face
    Face Posts: 14,340
    edited March 2008
    tcrossma wrote: »
    You're correct.
  • Racker99
    Racker99 Posts: 13
    edited March 2008
    Yes, it's like a line-out level. I expect that I'll have to adjust the volume level for the Left / Right channel on the amp separately from the receiver.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2008
    Go back to ebay and bid on a Harman Direct 2xx or 3xx series AVR that has pre-outs. Should be able to stay around $200. It's the cheapest way I know of to get a nice sounding pre for your TFM25.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Lowell_M
    Lowell_M Posts: 1,660
    edited March 2008
    Ron Temple wrote: »
    +1...
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
