FS: Audes SOUL Loudspeakers
RuSsMaN
RuSsMaN Posts: 17,985
Full range, incredible sounding speakers. One of the fastest and most detailed midrange I've heard. Big, heavy, well built with hand made, custom matched drivers. Front ported, bi wire/ampable, optional plinths included. Original manuals and spikes included. Matched L&R pair.
Cosmetics are very good, minor chip on the rear and a hairline scratch on the side of one speaker. Retail was $2700 for the pair, they are about 5 years old.
This is high end. $old Gadabout
Specs:
Nominal impedance 8 Ω
Max. long term power 130 W
Max. short term power 200 W
Frequency range (±2 dB) 38 - 20000 Hz
Lf corner (-6 dB) 32 Hz
Crossover frequency 300/3200 Hz
Sensitivity (2,83 V/1 m) 88 dB
Speaker drivers:
8" cone type woofer
4½" cone type midrange
1" soft dome type tweeter
Dimensions (inches) 40" H x 11½" W x 16¾" D
Base 13" W x 16¼" D
Dimensions (mm) 1015 H x 290 W x 425 D
Base 325 W x 408 D
Weight 40 kg/88 lbs
Post edited by RuSsMaN on
