amping help
Hello
My main goal is to bi-amp my rti10 but I feel like I'm leaning towards a 7 channel amp. Do the rti6, rti4 and csi5 benefit a lot from bi-amping or should I just stick to bi-amping my mains?
Some options I am considering are buying the avr655 when it comes out as my current avr645 is only hdmi 1.1 with only 1080i; then using both effectively giving my 150watts*7, or using a b*k 125.7 s2 which with receiver would net 200 watts a channel or lastly add a 200.2s2 netting 275watts just for mains. Is there a big difference between 150 and 200 watts or 150 to 275 or 200 to 275?
Any advice would be great, one last thing I don't use a sub and I have my cross over set as follows are they ideal
rti10 - large
csi5 - 40
rti6 40
Should I bump my csi5 and rti6 to 60 or leave them at 40?
Thanks for help in advance
rti10 - large
csi5 - 40
rti6 40
Post edited by StevenFo2 on
Keep the AVR you have, unless you want the HD sound. 1080i vs 1080p isn't going to make a difference.
Get either a quality 2 or 5 channel amp. With the 2ch run the mains with it, with 5 channel you can run either all 5 or bi-amp the mains and run one channel for the centre. I would not bi-amp using a receiver and an external amp, although some do. -
If I was going to bi-amp, which I'll never do, I would only worry about the mains.
The rest is a waste of money unless you live in a soccer stadium. The difference between those power ratings is negligible and may be more noticeable between the actual manufacturer.....but some folks don't believe that either.
Sami has a good suggestion for power distribution with an external amplifier.
If the settings sound good to you, then they are ideal.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Lose the need for more power and put the $$$ into a nice sub. A sub will give you more bang for your buck with your current setup than any amp/wiring choice.
The difference between the wattages you are looking at is around 1-2 dB at full volume.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Hello
Thanks for the responses, so to rephrase basically I have equated higher wattages to better quality sound when it really is about higher volumes.
So more questions,
I have rti6 for rears but I noticed the audio doesn't seem as good as my rti10 fronts, is this because 5.1 tracks don't use as detailed tracks for rears like the fronts? I currently use 16 gauge speaker wires with the rear lengths being about 15feet.
Not sure what I will do amp wise, I like all three options but getting a good sub also makes a lot of sense which Polk subs do you recommend, I currently have a psw10.
What is dampening factor? Also do you recommend banana plugs?
Thanks for your help. -
Hello
So more questions,
No, the difference between 150wpc and 200wpc is not worth worrying about....based on the examples you posted. If it was 150wpc vs 300wpc.....well, you might have a noticeable difference at that point. The quality of the power, and/or manufacturer, will also factor into this power struggle. Not all gear is created equal. It's not about volume, its always about gain.
Surround information isn't as obvious as front stage information...that's the whole point of surround sound. If you could always localize it....it would be 1970's Quadraphonic.
Banana plugs are very convenient.
Damping factor isn't even a factor at this juncture. Get some more audio under your belt before you worry about that specification....and even then, it's not that important in the big picture.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
A lot of good information here. I agree a better sub would be my next recommended step. I do think you should at least try raising the crossover for your center and surrounds as 40 is below their -3dB limits.
Just to make sure you understand, when adding an amp you don't add the power from the receiver and the amplifier. When you add an external amplifier the AVR amplifier goes unused so you only get the power the external amp is rated at.
As for what sub, if I was looking at Polk the only one I would be interested in is the DSW 600.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
Hello
So if I add an amp my receiver essentially becomes a pre-out and the amp does all the work. Is the reason for this so that you can send the full amp signal without limiting the power to the speaker’s crossover? Is it not possible to run my receivers wire to the top terminals(high freq) and use the amp for the bottom terminals(low freq) on the speaker?
Thanks again -
:eek: Don't let Cathy know you said that... -
... one last thing I don't use a sub and I have my cross over set as follows are they ideal
rti10 - large
csi5 - 40
rti6 40
I would also bump the crossover to 60 or even 80 Hz on those speakers. 40 is essentially running them full range as it's well below their -3dB limit. -
He doesn't use a subwoofer so there's not much point in crossing them at all, let alone raising it to 60.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I think the damping factor on some old Mcintosh gear that sells for thousands of dollars on e*bay is around 10 and people think they sound spectacular ... you look at modern SS amps and they say damping factor 40, 80, ... 300
Where was it that I read 20 or 40 is more than enough, and anything beyond that is meaningless?
W -
It's not a meaningless factor but not as important as some folks think.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I have a onkyo 805 powering two Monitor 70's as my surrounds and a new, in-transit, pair of TRi 12's, my center is a CSi5?. I have heard these 12's suck power. If they don't sound good on my 805 I have a 200 w/ch Adcom gfa 555 power amp. 2 questions Sami...... 1. How do I bi amp just the two front RTi 12's? 2. Why don't you recommend it? Thanks... Would I run a interconnect from which preout on the receiever to the amp?Keep the AVR you have, unless you want the HD sound. 1080i vs 1080p isn't going to make a difference.
Get either a quality 2 or 5 channel amp. With the 2ch run the mains with it, with 5 channel you can run either all 5 or bi-amp the mains and run one channel for the centre. I would not bi-amp using a receiver and an external amp, although some do.RTi 12's main
CSi5 Center
Monitor 70's Surrounds
PSW125 Sub
Onkyo 805
Fronts Adcom GFA 555 powered
I/C's from the wall of Circuit City
Wire by BlueJeans at $.65 per foot -
Yes, but why not let the 10's try to handle the lower end of the center and surrounds? When the sub is finally there he could just tweak the bass management for fronts, but the rest of his system would already be dialed in.
my 2 cents
- Val -
He already has the fronts set to large. I understand but it's not that hard to quickly adjust for the addition of a subwoofer unless he doesn't have fingers.....so you may have a point.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Replied to your e-mail. Here's my answers for everyone to see, in case some of you disagree:
How to bi-amp:
You would first disconnect the blade between the binding posts on your speakers. This is the gold metal plate that connects them.
Run interconnect from your receivers L/R preout to your amplifier.
Run speaker wires from your amplifier to the bottom post on your speakers. Run speaker wire from your receivers L/R output to the top posts on the speakers.
Why I would not bi-amp with receiver and amplifier:
First, the receiver might shut off the amplifier section if it detects there is preout connected.
Second, you most likely have different gain on the amplifiers, this why I only recommend bi-amping with the same amplifier. Why does it matter, well if the amplifier is 2dB hot compared to the receiver, you will get 2dB more sound on the frequency section of the amplifier. Not good but some people won't notice it. You can get around this but it's way more advanced issue than bi-amping.
Third, the Adcom is 200WPC, more than enough to drive the 12's. Not worth the trouble to bi-amp with different amps. You can try of course, you won't lose anything. Compare it to the Adcom alone and see for yourself which one you like better.
