How do I change the speakers in a new beetle?
Systems
Hi, i would like someone to tell me how do i change the speakers in a new beetle.
Testing
Testing
Testing
Testing
Testing
crutchfield will you send you papers of how to do it when you buy speakers from them, but im not sure if theyll just send them to you
theyre customer service line(toll free) is 18009559091
maybe they can help
-Cody -
Take your car down to the local Chevy dealer and trade it in .Then come back and ask again.
1. Insert key's into VW...
2. Find the biggest cliff...
3. put the VW in nuetral
4. give it a good push...
LoL J/k umm I would try cruitchfeild or if you have a Chilton manual for that vechicle it give instruction on replace the factory OEM speakers
Good Luck
Sir Daniel X. Boom - the GNX slayer -
pull the panel off -- use a screwdriver to get the speaker out -- put the new speaker in -- test to make sure it works -- put the panel back on.
then trade it in on a chrysler crossfire.The Artist formerly known as PoweredByDodge -
lol...thats just wrong
but ive been in the turbos before...
theyre pretty damn fast
**** handling...but pretty fast
too bad i cant fit in the back seat...
-Cody -
Are you lookin' to do fronts&rears? or just one? They're pretty easy once you know what to do. Front doors trick is getting window crank off (if not power windows) and the trick to the rear speakers is you need to pull the lip of the side panel that is parallel with your rear side window UP and then pull the panel off. You need torx drivers to get the speakers off. And dont let these other guys knock the beetle. My girls is the peamp-ist import down at the spot.Testing
Testing
Testing
