Using Coaxial RG-6 for IC's?
2
  • jakelm
    jakelm Posts: 4,081
    edited February 2008
    ShinAce wrote: »
    It is 20 gauge stranded center and only 72% shield coverage. Poor shielding.
    Damn, i figured something was wrong for $19. Its very hard to find solid copper coaxial, at a good price.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • unc2701
    unc2701 Posts: 3,587
    Yeah, you can do better- poor shielding and the capacitance is a touch high.
    Backburner:Krell KAV-300i
  • jakelm
    jakelm Posts: 4,081
    I found this. 100 ' for $40. 95% shielding
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=100-300
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    ShinAce Posts: 1,194
    It has spare conductors, but looks fine.
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    And a good price. Thanks Ace
    Now to figure out what size and what RCA plug to buy.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Eric W
    Eric W Posts: 556
    Why don't you just use RCA connectors for RG59? If you get the compression style, you'll need the crimp tool too:
    Here are female RCA, wall plate female connectors:
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=092-712
    Here is the solder type male plugs:
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=091-400
    -Eric
    -Polk Audio
  • jakelm
    jakelm Posts: 4,081
    Thanks Eric.
    I bought this plug.
    http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=091-120&CFID=21794565&CFTOKEN=18752688
    And this cable.
    http://www.partsexpress.com/pe/pshowdetl.cfm?&Partnumber=100-300&CFID=21794565&CFTOKEN=18752688
    And a coaxial cutter.
    My first DIY IC's so I will see how it goes. And I can solder pretty well. I will pick up different color shrink tubes.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • WilliamM2
    WilliamM2 Posts: 4,807
    Why not use wire made for the job?
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=100-282
    Is there a reason you want solid core? If you are pulling that cable through a wall, stranded is more flexable, and much easier to pull as well.
  • jakelm
    jakelm Posts: 4,081
    WilliamM2 wrote: »
    I assumed, 22 awg wire was too small to make 30' runs.
    and I didnt see that wire...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Should I cancell the coaxial order????? And get the mic wire instead??
    Dmanit Will, where were you hours ago with this new information???
    wait till after I order the damn cable to speak up...I should bust you upside the head....:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Eric W
    Eric W Posts: 556
    jakelm wrote: »
    Ahhh those plugs, I've used them before. Be careful not to overheat while soldering the center or you'll have a nice misaligned tip that won't fit into the hole :)
    WilliamM2 wrote: »
    Well, he asked about using RG-6 for an interconnect. The mic cable will certainly work, but the solid copper coax will be fine too. While stranded is going to be more flexible then solid- if its being run in the wall you really don't need that much flexibility. I mean its going to be no different then running the cable for satellite or cable TV.
    Speaking of which to the OP, make sure you don't run that cable parallel to any electrical wires, leave plenty of slack at the ends, no sharp bends etc...
    -Eric
    -Polk Audio
  • Eric W
    Eric W Posts: 556
    jakelm wrote: »
    22 AWG is fine for line level signal. In the pro audio world, snakes are commonly 22 AWG running hundreds of feet (although they are balanced).
    -Eric
    -Polk Audio
  • jakelm
    jakelm Posts: 4,081
    The 2 cables are about the same price. Which would be a prefered method? Mic cable or coaxial?
    I can call and cancell if the mic is prefered.
    The IC's that i am building will be used in multiple ways, to run 30' to another sub and 4' to amp. So they will be cut into different lengths.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Eric W
    Eric W Posts: 556
    Here's another thing to consider- the mic cable does not appear to be certified for in-wall use while the coax is. Typically all that means is the jacket is abrasion resistant for pulling through the wall and the levels of emissions should the thing ever catch fire.
    As for which one- well, its up to you! :) I'll say, if you're going to have the wire sticking out of the wall (without a wall plate) I'd say go for the mic cable. On the other hand, if you're planning on using a wall plate on both sides, then go ahead and use the coax able.
    -Eric
    -Polk Audio
  • WilliamM2
    Here is a question I've always wondered about. If you use cable coax, you are using the outer braid for one of the signal wires. Is this really shielded?
  • jakelm
    jakelm Posts: 4,081
    Eric Wong wrote: »
    And the mic cable sure seems easier to work with (splicing a soldering wise). Dont ya think?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Im not going through walls. Running under house.
    Anyways, PE already shipped it out.... Damn they are too fast sometimes...
    AHHHHH but wait. That coaxial comes with an additional 18 awg copper wires. I will use the coaxial for the sub and make smaller IC'c with the additional 2 18awg wires....
    Look...Not all is lost.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Eric W
    Eric W Posts: 556
    WilliamM2 wrote: »
    The outer shield would be used as the "return" path and act as the shield, just like any other line level audio cable (except the "twisted pair" type).
    jakelm wrote: »
    Yes it will be.
    -Eric
    -Polk Audio
  • jakelm
    jakelm Posts: 4,081
    I edited my post above...sorry...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    WilliamM2 wrote: »
    The shield is connected to ground, and therefore cannot carry a signal. It is the difference between the shield and center conductor that carries the signal.
    Here's a question for you. If a cable had an outer conductor in coaxial configuration that wasn't connected to anything(free-air), would this provide sheilding?
    It is not the physical presence of the shield that provides shielding, it is the voltage that it carries that performs this function.
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    Does aluminum foil protect a potato in an oven?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    From prying eyes...yes.
    From prying forks...no.
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    Go to red alert!!!!......Raise shields Lieutenat Worf
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    Aie Captain!
    Aft shield is down to 95%.
  • jakelm
    jakelm Posts: 4,081
    Damn Romulan volts, trying to get through our shields..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Damn...Heat shrink is expensive....
    $1.40 for 1 color 1 strip. I thought I saw it cheaper @ my local rat shack
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    We used to sell it $ 2 (canadian) for a 4 foot length. After having that deal, I find all heatshrink expensive. I would get it at cost for roughly 75 cents a length.
  • WilliamM2
    No, but I have seen cables where the shield is connected to ground at only one end, and then they use two conductors in the center. Supposedly to help stop ground hum. But then the ground lead in the center is still connected to ground at both ends, so I.ve never really under stood how it helps.:confused:
  • ShinAce
    If I have a wire that is a million feet long connected to ground at one end, the entire length is now a ground connection.
  • jakelm
    jakelm Posts: 4,081
    ShinAce wrote: »
    Oh yeah, but what if its 1,000,001 feet??
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
