Too Much Air Space??
jakelm
Built a new enclosure this weekend for my SVS 12.1 w/ Rythmik amp.
Something didnt sound right. The dems are 17"W X 18.5"D X 44.5"H, using 5/8" MDF board. 4" port 19" long.
I dont have the SVS parameters so I cant use winisd.
I thought I had too much air space, so I added poly fill. Still doesnt sound right.
Not sure if its the amp or sub or box or all of the above.
My guess, after all the poly fill is, its ~6cuft. Might still be too much for the SVS? I dont want to start cutting w/out other opinions.
I wish SVS would release parameters for thier drivers.
Or I might just replace it with a Titanic III 15".
I will try to get some pics up.
Thoughts?
Jake
Thoughts?
Jake
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Post edited by jakelm on
You don't really need specs. The box volume and tuning frequency have been stated.
Assuming you gave the external dimensions, your box has 6.8 cubic feet of space, minus driver displacement and 0.14 cubic feet for the port.
As a ballpark guess, you are tuned around 20 Hz. I'm at work, so I can't tell you for sure what the tuning is, but I figure you know very well.
Polyfill will not do much for the airspace of a vented box, it primarily will absorb midrange frequencies.
You can always try stuffing the box with solid objects to reduce the airspace. Bottles full of water might do the trick, if you have enough of them.
Best of luck. -
Thanks Shin. A second measuring did a pretty good job at what I'm working with.. I posted a graph in the other REW thread I have started..Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
OK its depth times width times length divided by 1728 and then minus any other ports or speaker displacement 6.8 is just a tad big is it not ?:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
Not neccesarily.
Adire Audio released some subs a while back that used boxes ranging from 5-7.5 cubic feet tuned to 20 Hz. The cerwin vega stroker wants a box that big to shine.
For HT, 2-3 cubic feet for a 12" is the norm, but 6 is not unheard of.
Jake, if you really wanted to, you could measure the specs. The easiest way is to take an impedance plot and send it to me. You will need an additional test to find Vas.
You would need to remove the driver, preferably hand it up in the air, and run a signal generator through your amp. You could use tones, but you will need tones from 10 Hz to 100 Hz at every 2 Hz minimum. The setup is just the speaker connected to the amp with a 10 ohm resistor in series. You measure the voltage across the woofer and then the voltage across the resistor and jot it down. Change frequency, lather, rinse, repeat. You'll want to use a low voltage for the test, roughly 50 mV across the resistor. The speaker doesn't even need to be audible.
It's a fair amount of effort with the possiblity of me coming back at you with "yep, 6 cubic feet is fine for the driver". Trust your ears on whether this is something you want to try. -
Measurement taken here. Looks pretty good and sounds good, so I think I'm ok, for cuft. I probably could chop it down and re/tune it, but then it wouldnt look so massive..:p:pMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
i used my old svs 12 for a truck sub box. no, svs will not give out the t/s specs on their subs. but the WILL help you design a box if you call or email them. they helped me out.
and jake, the polyfill only tricks the sub into thinking the box is BIGGER than it really is.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
They actually gave me some info, that the 12.1 was the same driver as the TC sounds 500 driver.
Found the specs over @ AVSforum.
Not that it mattered, 'cause I am way over spec anyways.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
you and me both. my box was just a bit too small for ported, yet a bit too large for sealed. i went with sealed and it hits low. still wish i had gone ported, though.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
It's never too late to operate. -
And....its easier to cut wood than it is to grow wood.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
What kind of wood are we talking about?
Partical wood.. MDF.
Very hard to grow it.:DMonitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Bizill
What kind of box did you build? sealed or ported? And how big is it? I was thinking of building one , but not sure if I have enough room.
Robmains: rt16
center: csi40
surrounds:fx 1000
sub: SVS 20-39pc+ -
BTW, i wouldnt do this.
i can think of at least three good reasons that this is a bad idea. maybe some gallon freezer bags filled with sand or something. i would probably double bag it, as well.You can always try stuffing the box with solid objects to reduce the airspace. Bottles full of water might do the trick, if you have enough of them.
OTOH, this technique absolutely works. it also has the added benefit of adding mass to the cabinet, while being acoustically inert.
agear list:
1 down, 4 up....
