Subwoofer overkill?
mhartman29
I'm about to venture into a new SW. I already have a few models I'm leaning strongly towards, but I'm curious if they'd be complete overkill for my room. My HT room is fairly small, about 200 sq ft. It also has a couple of windows on one side and it's mostly open to the another room on the other side.
I'm really looking at the av123 mfw-15 or the Epik castle, but would those be overkill for this size of a room? Would I be better off with a less powerful Epik like the Knight or Valor?
I'd say I lean 50-50 on music versus HT. I don't need the room to explode with bass, but I want good power and SQ.
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Analog II ICs
Signal Ultra speaker cables
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Post edited by mhartman29 on
I'd think cubic feet is more important, as well as room layout and placement.- Onkyo TX-SR805
- Polk RTi8's Main L/R's
- Polk CSi A6 Center
- Polk FXi3 Surrounds/Rear Surrounds
- HSU VFT-2 MK3 -
If you can afford a nice sub, why not. My sub right now is overkill. It just means I keep it to a reasonable level.
The sub placement will have the biggest effect on its performance, next will be the room layout and then the volume. -
Overkill??? I didn't know there was such a thing.:D
nikolas812 wrote: »Overkill??? I didn't know there was such a thing.:D
LOL, that's what the guys at Epik said!
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
Signal Ultra speaker cables -
Even if you do buy a sub that's too "big" for your room, you can always set it down a bit. That way if you ever move to a bigger room, or decide you want more bass, you don't have to go buy a new sub.Polk Audio RTi8 Fronts
Polk Audio CSi A6 Center
Polk Audio RTi A3 Surrounds
Polk Audio PSW505 Subwoofer
Onkyo TX-SR805
Sony Bravia V5100 46"
Sony Playstation 3 160GB
Sony Playstation 3 120GB Slim -
Ditto. -
bass = setting the air in the room in motion. i went from a single to double sub yesterday and was a day and night improvement - standing wave issues is pretty much fixed.
only problem now...the subs would stay on
my 7.(1x4) HT setup
TV - Mitsubishi WD-65734
AVP / Amp - Onkyo PR-SC885P / D-Sonic 2500-7
Front - Emerald Physics CS2
Center - JTR Triple 12LF
Surround L/R / Back - Polk RTi4 / Polk FXi A4
Sub - 4 X Hsu ULS15 playing nearfield
DVD / CDP - Sony PS3/40GB / Sony SCD-XA9000ES
Belkin PURE AV PF60 / UPS
Buttkicker
http://www.polkaudio.com/forums/showthread.php?t=60612 -
I have an Mirage Omni S-12 and LOVE it. Great sub with great looks to boot.
They retail for $800 but can be found for much less. . . if you can find one. Tweeter used to carry them and sold them off for half price at one point.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
mhartman29 wrote: »I'm really looking at the av123 mfw-15 or the Epik castle, but would those be overkill for this size of a room?
Huh? Overkill?
My room is slightly larger than yours, and I'm looking at adding another 15" sub. If I didn't have WAF constraints, I'd have a sub in all four corners.
BTW, both of these subs are excellent options. I look forward to your review.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
My room is about the same size as yours and I run a pair of these.
http://svsound.com/products-sub-cyl-csplus2.cfm
Remember these ones are passive though so you need a couple of amp channels to drive them. I love em, and in no way are the overkill since they acoustically couple if they are not too far apart.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Well, I have an order in for a Castle and one for dual MFW-15s, since they are about the same price. I guess I'll let fate decide (via who ships first) which one I get. I'm at a loss for determining any other way!
Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
mhartman29 wrote: »Well, I have an order in for a Castle and one for dual MFW-15s, since they are about the same price. I guess I'll let fate decide (via who ships first) which one I get. I'm at a loss for determining any other way!
Keep both of them.;)HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
On Craig's point system you're about equal...price about equal...so that's as good as any way to decide. I don't think you'll have one regret with either solution.
Be sure to let Mark and Chad know they are competing...might get a sub or two faster
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Assuming, per craigsubs list, that 2 mfw-15s will give relatively equal performance to 1 castle, is there any reason to favor the dual sub setup? I hear some people say using 2 subs makes a big performance improvement. Assuming, of course, that 2 castles is not an option in the foreseeable future!Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
mhartman29 wrote: »Assuming, per craigsubs list, that 2 mfw-15s will give relatively equal performance to 1 castle, is there any reason to favor the dual sub setup? I hear some people say using 2 subs makes a big performance improvement. Assuming, of course, that 2 castles is not an option in the foreseeable future!
6 of one...
Dual MFWs co-located will have ~ the same output as the Castle except at the very bottom. You might get a better FR in room with duals or you could have cancellation issues...depends on your placement options...either way you'll have to tweak the sub(s) for optimization. With either option you will have awesome bass output. How big is your room?
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
My room is about 2800 cubic feet, but it is also open to another room of similar size. Placement is actually my biggest worry, since I don't have too many options.
Now that I think about it, I probably need an additional plug if I'm going to have it close to the rest of my equipment. Will it be too much for a single outlet to handle my amp, plasma tv & a SW or two?Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
You should be fine with either sub(s), however you might want to split up the load on a couple of circuits. The Bash amps are pretty efficient, but you might be drawing 750 watts from time to time...what's that?...about 5 amps I think. With the rest of your gear, I'd want either a dedicated 20 or 2 15s.mhartman29 wrote: »My room is about 2800 cubic feet, but it is also open to another room of similar size. Placement is actually my biggest worry, since I don't have too many options.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Are there any general guidelines for SW placement? Or does it pretty much depend on the layout and acoustics of your room?Emotiva LMC pre/pro
Emotiva LPA amp
Fronts LSI15
Center LSIC
Rears LSI7s
Dual MFW-15s
Oppo 980H
I have some sub overkill!
No such thing!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
