Jolida Binding Posts
nikolas812
Can someone tell me where to buy some binding post for my jolida that excepts banana posts? I have a old model jolida that does not except bananas and I can't stand it. I want to buy some immediately. Please help. I have looked everywhere.
Nevermind. I just found them. "Termination Binding Posts" in the search box finally provided some results.
Heres a link to the site if anybody is interested.
http://www.oregondv.com/Terminal_Binding_Posts.htm
Is there any way you can delete your own threads?
Post edited by nikolas812 on
Try the following:
www.partsconnexion.com
www.partsexpress.com
www.madisound.com
www.ramelectronics.com
www.vhaudio.com
www.tweekgeek.comHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Here are a couple more:
www.diycable.com
www.percyaudio.com
I use Percy on a regular basis, his prices are good and he is actually really easy to deal with. -
Be careful, all the binding post on your link are for speakers, they are not for chassis mounting. Chassis mont posts have insulation for mounting on a metal plate, such as the back of your Jolida. Those posts you linked to would short the positive and negative terminal to the chassis. Not good. -
Hmmmm. Thanks for the heads up. I thought they looked just like the ones in my other Jolida. I think I can probably make them work. If not its no big deal. I will just have some more cool spare parts lying around. I noticed everybody gave me a lot of links but it is obvious I need for somebody to find the part for me and then leave a link. It seemed even when I think I have found the correct thing it is wrong.:( Thanks for everybodys help though. I am gong to search some of those links some more and see if I can't find something that would work better for my application.
Check out www.cardas.com or do a search for WBT....If I was replacing binding posts ONCE, I wouldn't cheap out.
Huh?? Is WBT short for something or do I actually type in the letters WBT?
WBT is a brand."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
OH.:o Where are the prices on the carda stuff? They look a little better than those $8.00 binding posts I bought.:D
President of Club Polk -
I think I will be going with the Cardas. The WBT's are way out of my price range for a binding post. Thanks for the sites guys. Those are some killer sites with some great stuff. Beats the hell out of the mono price stuff. I would hope anyway.:D
Nice, which ones are you going with? I am thinking the same thing, maybe the Eichmann Cablepods for one of my projects...
These would work:
http://www.diycable.com/main/product_info.php?cPath=26_136&products_id=606
I just ordered 6 pair, I've wanted to replace the posts on my amp because they don't accept bananas.
Thanks for the link Bill A.
