RD1098-1 and RD1094-1 difference?
Loco57
I know this may have been explained previously but I am getting conflicting information on the above tweeters from Polk. Having contacted Polk via the company I deal with in Australia I have been advised that the correct replacement tweeter for the SDA SRS speaker is the RD1098-1.
My question is what if any difference is their between the RD1098-1 and the RD1094-1 tweeters as I am now thoroughly confused as to what is the correct driver. I previously contacted Polk via the support line on email and received no reply unfortunately.
The company I deal with has 8 drivers in stock of the RD1098-1 variety so is this the correct way to go?
Post edited by Loco57 on
The 198's replace the sl 3000 or the tl versions of the Monitor or SDA speaker lines. The 194 replace the sl 1000 sl 2000 and sl 2500( I believe). Some of the long time members may have some more info for you.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Here in the states Polk recommends the rd0194 for your speaker but maybe there, they have been using the rd0198.
The rd0198 is a drop in replacement and will work but has a wider connection terminal on the positive so you would have to make some kind of adapter like I've done on my 2.3's to replace the sl2000's with the sl3000's.
I prefer the sl3000's over the rd0194's but I haven't heard the rd0198's.
http://www.polkaudio.com/forums/attachment.php?attachmentid=31066 -
Please tell us which model tweeter you have now, so we can point you in the direction of the CORRECT replacement."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
candyliquor35m wrote: »I prefer the sl3000's over the rd0194's but I haven't heard the rd0198's.
http://www.polkaudio.com/forums/attachment.php?attachmentid=31066"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
If you have the sl2000 (fisheye, opaque dome) tweeter as your original tweeter then the RD0194-1 is the CORRECT replacement.
If you have the sl2500 or sl3000, both blackish/goldish dome with a foam ring around the dome then the RD0198-1 is the CORRECT replacement.
Since the info on the tweeters is proprietary there is no spec sheet or freq. response plots to show the difference. Rest assured based on what Ken at Polk has stated and what members who have used both have stated, they ARE DIFFERENT both electrically and sonically.
One other thing is the terminals on the RD0's are not the same. The 194-1 has (2) small male connectors whereas the 198-1 has 1 large and 1 small male connectors. That's the easy way to tell the difference between the two.
It is unfortunate that e-mail doesn't get answered where phone calls get answered right away.
My guess is your supplier is trying to move those RD0's and is feeding you a line or they possible don't know or feel that the difference is negligible.
I hope this helps and I pray this thread doesn't spiral way off topic like the other one. I know with you being litterally a world away that using the RD0198-1 might be more convenient since your dealer has them (supposedly) you are going to have to make that call yourself. They aren't exactly correct and may or may not sound better than the originals.
I am really suspect of your dealer because first they told you they had sl3000's and sl2500's now they have the RD0198-1, seems fishy to me. If you can look at the physical tweeters they have you should be able to tell.
sl2500 and sl3000 have a blackish/goldish dome with a foam ring around the dome.
RD0198-1 has one large and one small male connector's on the back
RD0194-1 has 2 small male connector's on the back.
If they won't let you see them or you can't because they are logistically too far away from where you are at, be sure and ask about returning them if they are not as advertised.
Good luck and again the best way yo contact Polk CS is by phone.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
candyliquor35m wrote: »Here in the states Polk recommends the rd0194 for your speaker but maybe there, they have been using the rd0198.
This is ridiculous to say "maybe there they have been using the rd0198-1". If they are, it's WRONG. It will work, yes but it's not the best choice but in his case may be the only choice because of his location. I'm assuming your dealer doesn't know too much and really the RD0 phenomenon is mainly on this board. You could call Polk in the states and get someone in CS who hasn't heard of the RD0. They may still send it to you as the replacement but may not know it by name."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Sda Srs - Rd0194-1
Sda Srs 1.2 - Rd0194-1
Sda Srs 1.2tl - Rd0198-1Political Correctness'.........defined
President of Club Polk -
CL, for the love of God STFU and stop confusing the guy.Political Correctness'.........defined
You stated yourself that your setup is unique. Warm cables, tube amp, etc... Under any other conditions they will be bright.
And the moral of the story is: "There's other ways to tame a bright tweeter than replacing it."
If I recall. Loco has not even indicated that he thought his sl2000's were bright. He's just wanting to replace one that gave out on him.
On a side note, I hope no one is throwing away their old tweeters. They would be invaluable to someone wanting to restore their polks to factory condition.
Loco,
Send a email to Ken in customer service and he will most likely answer your questions promptly: http://www.polkaudio.com/forums/member.php?u=13098 -
candyliquor35m wrote: »And the moral of the story is: "There's other ways to tame a bright tweeter than replacing it."
Loco,
JHC, the moral of the story is "he didn't ask how to tame a bright tweeter". He asked what the CORRECT replacement tweeter was according to Polk Audio.
I can't believe you're not getting this!!!!!!!!!!
Gentlemen,
I went to the agent yesterday and physically saw the tweeters yes they are shiny black with one large and one small terminal no surround and without any identifying decal on the magnet area.
To clarify something the dealer didn't say they had sl2500's in stock but stated that they had sl3000's that were a later replacement for both the sl2000 & sl2500 units I can only assume that the RD098-1 part number cross references to the old sl3000 tweeters.
I had a call from the dealer this morning and was informed that PolK US had advised that the RD098-1 was the correct replacment item for my sl2000 tweeters and that on checking they had 8 items in stock.
It is more likely that information on the RD094-1 option is not prevelent amongst the service/spare parts in POLK US than any issues I am dealing here or any ulterior motives on the part of the supplier.
Basically I just want to make the right selection first time! -
The cheapest route for you is for someone here to mail you a sl2000 which I'll be glad to do for $30USD. Heck someone might even do it for free or just for shipping.
RD0194-1, period.Political Correctness'.........defined
Gentlemen,
Then that is the RD0198-1.To clarify something the dealer didn't say they had sl2500's in stock but stated that they had sl3000's that were a later replacement for both the sl2000 & sl2500 units I can only assume that the RD098-1 part number cross references to the old sl3000 tweeters.
The sl3000 DID replace the sl2000 but they are not cross compatible. The speakers that use the sl3000 have a different x-over. The sl2500 also replaced the sl2000, but in the Monitor/RTA line only, again not cross compatible as the x-overs are different.I had a call from the dealer this morning and was informed that PolK US had advised that the RD098-1 was the correct replacment item for my sl2000 tweeters and that on checking they had 8 items in stock.
Not sure who called but that is not a correct statement.It is more likely that information on the RD094-1 option is not prevelent amongst the service/spare parts in POLK US than any issues I am dealing here or any ulterior motives on the part of the supplier.
Internally at Polk HQ the RD0194-1 may go by a different moniker. The sl2000, sl2500, sl3000 haven't been manufactured for many years but they might still call them that, but there is no more stock of these tweeters at Polk HQ unless they unearth a stash from a while ago.Basically I just want to make the right selection first time!
RD0194-1 is correct; and it sounds like from the physical desc. you gave in the first paragraph those are the RD0198-1 the dealer has.
Good luck
Candy,
not sure why you believe I have a dud tweeter in the system as all are operating.
H9,
I belive you are right with regards to the mixing of part numbers verses old references if you teel me my description is correct for the RD0194-1 is as above I will ring now and secure the items.
Now all I need is for my electronic components to arrive and then all will be complete for the upgrade just hope it will all be worth it. I have document exactly what I have done step by step with photos so when it is all finished I will post with the results.
Hopefully it will all be good! thanks to all once again. -
Here we go again...Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Then that is the RD0194-1 which is the correct replacement tweeter
When I ordered 2 rd0194's from polk to replace my sl2000's, they sent me tweeters with 2 narrow terminals.
When I replaced my sl3000's with sl2000's, the sl3000's had a wide terminal and a narrow terminal so I had to make a wire adapter to hook them up.
Loco,
Polk might think you have SRS 1.2TL's. Can you give us more info like the serial #'s, whether you have the blade/blade or the pin/blade interconnect cable or any of the other distinguishing differences between the SRS and the SRS 1.2TL. -
HOLD the phone Loco!!!!!
I made a mistake!!!! The RD0194-1 has (2) small male terminals whereas the The RD0198-1 has one small, one large. I apologize I don't know where my head was.
It appears according to your desc. they have RD0198-1's at your dealer.
Pics are hard to come by but here's a couple of the RD0194-1. The only way to tell them apart is the terminals.
Again I apologize for almost having you get the wrong ones."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Also if it hasn't been mentioned KEEP the tweeter gasket material from the originals as the new ones don't come with gaskets.
Here we go again...
Before "we go again", I'd like to congratulate Loco57 on his composure, well thought out questions, and especially his remaining focused on the task at hand (opinions aside). I look forward to seeing his upgrade report.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
I didn't mean anything against him...quite the contrary. I commend him as well on he well thought out questions on the speakers and wanting to find the correct and proper replacement.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Marty,
thankyou for the compliment, I assume your reference to "opinions" is related to the comment in previous posts on cabinet build quality on my speaker set? -
WTF??? I told you a week ago what tweeters you needed, why is there still a question?
"The only tweeters that you can use in your SDA SRS's are the SL2000 or the RD0194-1. That's it, period.
The SL2500 did not replace the SL2000, nor did the SL3000 replace either of those. They were simply tweeters with different specs used in different speakers. Again, neither one will work properly in your speakers."
Hell, I didn't even get a reach around.Political Correctness'.........defined
Yeah we kind of discussed this already http://www.polkaudio.com/forums/showthread.php?t=63121 but we can do it again if you want.
Speakers are ordered will pickup Monday, what can sometimes be confused with stupidity can also be related to thoroughness I subscribe to the second column:D
I can appreciate your frustration in providing the correct information to a question posed only to have it queried in a second post ( not my intention ) but in my case over here I am dealing with suppliers that are not privy to information commonly circulating in the US.
So you see my dilemma when I get conflicting information it is best to see the item with your own eyes and make the informed decision and this is what I have done.
The selection I have made and the end result will see if it has all been worthwhile, as stated earlier the least I can do is document what has been done and post for all those interested in the results.
Before I get to that stage I will need some information on the best way to post this information. -
Just review the various topics: http://www.polkaudio.com/forums/index.php and post away.
candyliquor35m wrote: »Just review the various topics: http://www.polkaudio.com/forums/index.php and post away.
Ummmm yeah, he's not an 8 year old he can figure which forum to post in. I'm gonna say he means how to arrange the information and probably how to post pictures. :rolleyes:"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
This thread became entirely too complicated for such a simple question. Thank you Face and heiney9 for grabbing hold and taking care of business.
CL, what is wrong with you? The man asked for a fact.....not your opinion....I'm willing to bet he could care less about your opinion. -
All this? over a simple tweeter replacement?JC approves....he told me so. (F-1 nut)
Marty,
Primarily that but also the tweeter discussion which in my opinion (there's that word again) digressed into opinions (again) about "what he said versus what he meant". All harmless really and good fun nonetheless.Speakers are ordered will pickup Monday, what can sometimes be confused with stupidity can also be related to thoroughness I subscribe to the second column:D
Loco57 - Darquekight, nspindel, myself, and others all have upgrade threads that could be used as examples. I can give you specifics on mine (email me) and I'm sure the others would as well.Before "we go again", I'd like to congratulate Loco57 on his composure, well thought out questions, and especially his remaining focused on the task at hand (opinions aside). I look forward to seeing his upgrade report.I didn't mean anything against him...quite the contrary. I commend him as well on he well thought out questions on the speakers and wanting to find the correct and proper replacement.
Kip, I wasn't referring to you - just the "here we go again" which I completely agreed with you about. It looked like the thread was starting to become a little argumentative (which it did, so good call there).Sony 60'' SXRD 1080p
TT = Audio Technica
