pro audio power amp as hi-fi amp? (sounds good to me)
  • madmax
    madmax Posts: 12,434
    edited February 2008
    furball wrote: »
    1000 watts? Wont that blow your speakers?
    Most any quality speaker will handle short peaks of that power range. By peaks I mean very short term peaks which most sounds are made up as. For example, the clank of a cowbell or a hit of the rim of a drum is fairly short. A cymbal can be quite a long sound but it is made up of many very tiny peaks. These are the things that make it up there in the 1000w region. A long sound like a voice or guitar note never has those very high peaks so they stay down in the reasonable range. A voice produced at more than 50 to 75 watts would leave you hurting because of the long duration of consistant power.
    madmax
    Vinyl, the final frontier...
  • ward91
    ward91 Posts: 338
    whats a "MAGNETIC FIELD POWER AMPLIFIER " please explain ,or try to.
    cheers
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
    F1nut Posts: 52,002
    ward91 wrote: »
    cheers
    Switching power supply.
  • ward91
    ward91 Posts: 338
    ah cheers :-)
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
    mhardy6647 Posts: 35,232
    Some of the "pro" amps (even some of the pretty cheesy ones) will work surprisingly well as home hifi power amps. An example was a two-channel 'pro' amp sold for some time by Radio Shack. These were in the 150 wpc range, fan cooled, and said to sound pretty durn good.
    This amp, or a reasonable facsimile, is still available under various brand names (e.g., "Pyramid" brand, from PartsExpress). The price is right...
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=245-525
    Here's another pro two-channel amp that sounds pretty good, Peavey Classic 50/50. It's all tube (outputs are push-pull parallel 7189s for nominally 50 wpc -- maybe more like 30 continuous watts per channel). This one's mine...
    (the output tubes are mounted sideways in the back of the amp, in front of a cooling fan. They're hardly visible in these topless shots).
  • carversound
    carversound Posts: 44
    A friend of mine gave me a pyle pro 3200 1600watt pro amp and it was pretty loud,they go for about $300. I hooked up the carver 1.5t and what a differance, 20x better sounding then the pyle. The peavey/ crown were better, but the carver was still alot better sounding. Sold pyle at pawn shop $100
    It's pretty hard to beat the carver m1.5t ($300 average price)
    That less than a $1 a watt. A true 350watt rms a channel
  • ward91
    ward91 Posts: 338
    how hot do these carvers get? just being looking at pics came across this pic of the inside of a 1.5t on ebay, how does it keep cool??
    are these avalable in the uk??
    ELECTRONICS
    arcam cd93
    linn wakonda
    MC2 MC450
    Teac ud h01 DAC
    SPEAKERS
    Tannoy DC6 t se .
  • carversound
    They just get warm! Bob carver was very good at making amps. He made the m1.5t to sound just as good as the Mark Levinson ML-2 a amp that cost 10x the price of the 1.5t.
    The early Carver "magnetic field" amp (the Carver Cube) used to often get warm enough to flame...
