Budget cable review
tonyb
Well,since I am not a pro reviewer,take this for what it's worth.After getting my hands on Ben's silver I/C's,I thought it only fair to give the man a review of his work.Pics are unavailable at the moment as the wife has snagged the camera for god knows what reason.The contenders are Bens silver I/C's.Mac palladium sound pipes,Z-SQUARED I/C's,which are a silver,gold,copper alloy.Test CD,and I only picked 2,are Dire Straits,Sultans of Swing,and Mapleshades,The Art of the Ballad.Both are excellantly recorded and were chosen for the difference in the pace of the music.As a side note,Bens cables only have about 80 hours on them,the others are well broken in.Rest of the gear is in my sig.Without going into too much detail,the test were done on all 3 cables useing the same track,then again on another track,untill 5 tracks were done on each cd.Cables were all placed between AVR and amp.
Mac soundpipes- Very very wide soundstage,nice lush highs,music seems to float,yeah,I know,you heard that before.Not as defined as I would like on individual notes.Guitar at the end of the Dire straits CD WAS spectacular.Not as dynamic as the others,though,and bass notes are a tad more loose than I would like.Best way to describe these are wide and lush with a sweet top end.Good budget cable.
Z-squared-Is my current cable and has been in my system for over a year.Not as wide of a soundstage as the macs but wide none the less.Sharp,detailed sound,with just a hint of harshness on the most very high notes.Bass is very tight and profound from mid bass on down to the basement.Drums sound awesome on these.Notes decay pretty accurately.A great budget cable that will compete with more pricier cables.
Bens silver I/C's- Practically identical to the z's.Wide sounstage,detailed,has a firm grip on all bass notes.Tad bit more air around notes.Very slight more forward than the rest.Musical notes have a nice decay and piano notes are razor sharp with the decay you would expect.Highs are still a hair harsh but this maybe to the lack of break in hours.Very dynamic also.
This is just my.02 on these three cables.None are over 120$.Associated equipment may have a play in this as I am useing a universal player to spin cd's.Universal was set to direct mode,and I/c's between the player and AVR were Z-squared.Bens cables have been in my system since I received them and I believe there they will stay.Ben builds some good stuff,and his build quality is also up to snuff.Highly recommended.For me,meshing Bens with the soundpipes would be the ultimate,but you know how this jouney goes.:)
Post edited by tonyb on
i'm not familiar with all three cables.. but I don't know if I would classify Ben's silver wires as budget..
PolkFest 2012, who's going>?
danger boy wrote: »i'm not familiar with all three cables.. but I don't know if I would classify Ben's silver wires as budget..
Bens are the cheapest of the 3 as price goes and yes,that is budget considering what other name brands go for.There is a huge difference between budget cables and the ones at rat shack.HT SYSTEM-
lsi 9's -
How can you even do a comparison with that Frankenstein amp of yours?:) Even though it is 200 watts or more....
P.S. all cables sound the same...
Venom -
Thanks guy's. I really enjoy hooking fellow Polkies up with these cables. Price wise just don't let the cat out of the bag;)
Tony which cables did you get from me. Braided, or the Star Quad?
Ben
Edit BTW Star Quads take a long time to burn in.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I like these wires mite be the best cable on the buget
http://www.carveraudio.com/phpBB2/viewtopic.php?t=4470&start=0
http://zebracables.com/1694.html -
carversound wrote: »I like these wires mite be the best cable on the buget
If you are on a budget, Blue Jeans offers the same Belden cable for half the price. -
Ben
Braided Ben.
I find it interesting what some consider a budget cable.Spend thousands on speakers and gear and look for 7 $ cables to wire it all up.What price point do you guy's consider,cheap,budget,normal,expensive,cables ?HT SYSTEM-
lsi 9's -
A cheap cable would be what comes in the box. A budget cable, maybe Monoprice <$10. Normal? I like to buy decently made cables, which can be had in the $20 - $30 range. System retails right about $13,000. If I thought expensive cables would make a difference, then obviously I would be willing to spend more, but I don't. -
we all have the amount we will spend on cables.. and i still hold ground that Ben's silver wires are not budget... IMHO and I don't even own any.
So you're telling us you don't think.A cheap cable would be what comes in the box. A budget cable, maybe Monoprice <$10. Normal? I like to buy decently made cables, which can be had in the $20 - $30 range. System retails right about $13,000. If I thought expensive cables would make a difference, then obviously I would be willing to spend more, but I don't.
"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
13,000$ AND 10$ CABLES? Gotta love it.
To me ,everything you listed is "cheap". Question though,why spend so much on the rest of the gear ? Really,I mean you could pocket alot of dough by just getting a Bose table radio.An audio signal is an audio signal,right? I'll stop here because the last thing I want is another cable debate and I can see thats where this is headed.HT SYSTEM-
lsi 9's -
I love how he said "If I thought expensive cables would make a difference, then obviously I would be willing to spend more, but I don't."
That says it all right there. Maybe he should TRY some more expensive cables first. Then if he doesn't like them, he can go back to the low end Monoprice stuff.
It's not hard to buy some used cables, try them out, then sell them if you're not satisfied. It's like a free trial. Which speaking of, Signal and a few other companies out there do offer a 30 day money back guarantee."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Don't waste your breath my man.
Just wanted to do a mini review and it has to turn into a cable debate.
Wish my computer had a "moron zapper" button.HT SYSTEM-
lsi 9's -
I don't think William is off the mark. Good quality, properly terminated cables should be fine. I like good cables, but I'm not going to drop a ton of money on them--there's far too many other upgrades that would make a much more signifigant change.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
You need to read better, I buy $20-$30 cables.Question though,why spend so much on the rest of the gear ? Really,I mean you could pocket alot of dough by just getting a Bose table radio.An audio signal is an audio signal,right?
Because gear makes a real difference, cables don't. -
Oh boy.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I have tried different cables, and heard no difference. I've even gone as far as to participate in DBT's, something the "trust your ears" crowd seems to be afraid of.
I don't use monoprice. -
You asked the question, and I answered it. That makes me a moron?
I wish my computer had a "Deluded listener" zapper. -
mine has an escape key.
I have pretty much decided that it does not matter what camp your in as long as you thought about it, after that its about enjoying the hobby as you like it.
RT1 -
You shouldn't coil speaker wire, it can create a inductor effect."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Yes they are my cables, some salesman talked me into buying them, I should have went with cheaper ones, but they do the job
Inductor, I hardly know her!!! Ha ha, I kill myself!!!!
I am uncoiling as I speak..... -
Do you need to use that adapter? Don't the pins fit in the binding posts?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I though Banana Plugs were easier to hook up.
They are, but if you can get away without a adapter, it's one less link in the chain."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I see your point
Thats all well and good if you don't believe cables make a difference.I did not ask that question.But if you believe that 100 bucks is not "budget",get real.
What ever happened to answers like......
" Hey,thanks for the review,glad you like 'em."
" I use so and so cables and really dig them"
" Good write up,I might give Ben a shout"
Did not want a debate thread,to bore me to death.HT SYSTEM-
lsi 9's -
I use Ben's cables, thanks for the review.
