weird smell from RTi10's
Mauskar
Mauskar Posts: 104
edited February 2008 in Speakers
Guys,
Im noticing a small smell (cant describe) while playing my RTi10's as fronts. My receiver is an HK 347, with the crossovers set to 100 + for the fronts (everything lower passed to the sub).
Any ideas, as I am not playing music loud, and its isnt bass heavy (ie, dave matthews, smashing pumpkins)
Thx
Post edited by Mauskar on
  • dkg999
    dkg999 Posts: 5,647
    It's the pair of Dorokusai's underwear that he had to dispose of on the last Polk factory visit. It will go away, eventually :p
    On a more serious note, are they brand new?
    DKG999
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    I always though Dave Matthews looked like he smelled funny. Billy Corgan looks like a germaphobe so I doubt it was him. Probably left over smell from Dave Matthews. :D
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • sucks2beme
    sucks2beme Posts: 5,681
    Electrical (ozone) or just a smell?
    Maybe that pesky mouse has some relatives,
    and is trying to get back at us polkies.
    http://www.polkaudio.com/forums/showthread.php?t=63327
  • Mauskar
    Mauskar Posts: 104
    LOL
    the speakers are new- had them for about a month. And pretty sure that there is no underwear floating around my speakers. Call it a hunch...
    LOL
    treitz3 Posts: 19,952
    Could you point us in the direction of this smell? Paint? Electrical? "Funky"? Rubber?
    Come on man, how 'bout a little hint?
  • Hi-Buy
    Hi-Buy Posts: 110
    Do they smell right away ? or only after listening for a while ?
    Big thanks to "Neskahi" !
  • ShinAce
    ShinAce Posts: 1,194
    Probably the glues in the woofer.
    If the box is ported, the port is guaranteed to give off the scent. If they are closed, check the woofer. Touch the dustcap with your hand to see if they are still warm after playing.
    This is a situation seen most often in car audio due to the power levels. How loud is "I am not playing music loud"?
  • Mauskar
    Mauskar Posts: 104
    Hi-Buy wrote: »
    they smell after listening for about 45 minutes, but smell more if i turn up the volume...
  • Mauskar
    Mauskar Posts: 104
    ShinAce wrote: »
    the towers are ported. i checked the porting and they arent warm. I normally play music and listen to the TV around -20 db...
    just want to make sure its not something severe like burning insulation on the wiring or something...
  • dkg999
    dkg999 Posts: 5,647
    You might have a cross-over component with a little glue slopped on it that is making some odor. You can call Polk Customer Service and discuss it with them.
    DKG999
  • ShinAce
    If you want to, crank them but not so loud that you have distortion to (speed up the break-in)/(find out if they're gonna quit on you).
    Sounds to me like it is the woofer only that is generating the smell.
  • Mauskar
    Mauskar Posts: 104
    ShinAce wrote: »
    Thought that it might be the woofers as well, which is why i set the crossover for the fronts above 100 (in my HK's menu). Everything below 100 is sent to the sub...
  • Face
    Face Posts: 14,340
    Smell aside, your bottom woofers are only being used from 100hz to 125hz. I would use a lower crossover frequency, such as 60 or 80hz.
  • Willow
    Willow Posts: 11,218
    don't know about that smell but those are not sats, so lower th xover or 80 for sure.
  • ben62670
    ben62670 Posts: 15,969
    10's I would run at 60-80hz, and I highly recommend an amp for them to take the load off the HK for the rest of the channels. Then run the mains as large(no XO) to get stereo LF out of them.
    Ben
  • Mauskar
    Mauskar Posts: 104
    ben62670 wrote: »
    Currently I am running them large, but set the cross over to over 100 so that the load would be taken off the receiver to power the woofers on the rti10's. Im planning on getting an amp, but not anything soon- tuition for med school comes first!
    is there a difference between the large and small setting?
    and what is a good amp- i know about adcom and rotels, but do i need 200wpc? If show can you point me out to a good and cheap 2 channel amp please..
  • Willow
    did you connect the sub with 1 rca type cable? if yes set the xover to small and 80. When you get an amp set it to 60 or lower.
  • Mauskar
    Mauskar Posts: 104
    Willow wrote: »
    one RCA cable. will give it a shot. out of curiosity, what will this do? reduce the load on the speakers?
  • ryanjoachim
    ryanjoachim Posts: 2,046
    I'm using just a single Digital Coaxial cable to connect my receiver to my DSW Pro 600...to my untrained ear it sounds pretty good
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • Mauskar
    Mauskar Posts: 104
    Im just using a PSW10 that came with the speakers. :(
    Maybe later i'll upgrade to a HSU or velodyne, but in due time. the amp comes first..
  • Face
    Face Posts: 14,340
    Digital coax is 75ohm just like a typical sub cable, should sound fine.
    Mauskar wrote: »
    In order to help you, what is the smell?
  • Mauskar
    Mauskar Posts: 104
    treitz3 wrote: »
    its hard to describe, but i want to say it smells like a circuitboard that has been overheated- kinda harsh tuna oil smell or something to that effect..
    tonyb Posts: 33,067
    Call Polk CS.Sounds like the crossover.And for gods sake man,lower that crossover to around 70,at 100,it's way too high.
  • djc9
    djc9 Posts: 37
    Mauskar wrote: »
    I actually had a similar experience when I pulled the RTi10's out of the box. Definitely a "tuna oil"'ish smell coming from the front of the speakers if I got really close to the grills to smell. But the speakers had never been played and after I set them up there was no increase in smell and the speakers have sounded great.
    I put a couple of reed diffusers on each speaker and there's no smell anymore. I figured that was that.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    Hi-Buy wrote: »
    Sorry but this could be an excellent slogan for Bose.
    I would call Ken Swauger at POLK CS about your speaks, he definetely does not smell.
    RT1
  • m00npie
    m00npie Posts: 697
    Mauskar wrote: »
    Is there a difference between the large and small setting?
    And what is a good amp- I know about adcom and rotels, but do I need 200wpc? If show can you point me out to a good and cheap 2 channel amp please..
    If you set your front channels as LARGE, how did you also set the crossover to 100? On my receiver and a few others I have seen, once you set the channel to LARGE, there is no longer a crossover option for that channel. Perhaps you set the other channels at 100.
    When set to LARGE, you eliminate any filtering by the crossover so you are sending the full frequency. As for the amp, well this question is asked at least 3 times a week so the search option is your friend. I can tell you the two amps that you listed will do well.
  • GSRBOB
    GSRBOB Posts: 172
    Mine smelled to when i got them. But not like a burned circuit board or cap. More like the construction of the enclosure.
    Onkyo TX-NR801
    Fronts- RTi 10's
    Center- CSi5
    Rear- Coming Soon
    Sub- Velo DPS-10
    Pwr- Monster HTS 3600
    LCD- KDL-40XBR2
  • Face
    Face Posts: 14,340
    m00npie wrote: »
    With some receivers/preamps, it's possible to set them to LARGE and still adjust the crossover. I believe I was able to with my Onkyo, HK, and Mac.
  • m00npie
    m00npie Posts: 697
    Face wrote: »
    Cool... Denon will disable the feature when selected as LARGE. Did you notice a difference with it crossed at say 80 with the front channels set as LARGE then at SMALL?
