weird smell from RTi10's
Guys,
Im noticing a small smell (cant describe) while playing my RTi10's as fronts. My receiver is an HK 347, with the crossovers set to 100 + for the fronts (everything lower passed to the sub).
Any ideas, as I am not playing music loud, and its isnt bass heavy (ie, dave matthews, smashing pumpkins)
Thx
Thx
Post edited by Mauskar on
It's the pair of Dorokusai's underwear that he had to dispose of on the last Polk factory visit. It will go away, eventually
On a more serious note, are they brand new?DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I always though Dave Matthews looked like he smelled funny. Billy Corgan looks like a germaphobe so I doubt it was him. Probably left over smell from Dave Matthews.
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
Electrical (ozone) or just a smell?
Maybe that pesky mouse has some relatives,
and is trying to get back at us polkies.
http://www.polkaudio.com/forums/showthread.php?t=63327"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
LOL
the speakers are new- had them for about a month. And pretty sure that there is no underwear floating around my speakers. Call it a hunch...
LOL -
Could you point us in the direction of this smell? Paint? Electrical? "Funky"? Rubber?
Come on man, how 'bout a little hint?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Do they smell right away ? or only after listening for a while ?Big thanks to "Neskahi" !
Probably the glues in the woofer.
If the box is ported, the port is guaranteed to give off the scent. If they are closed, check the woofer. Touch the dustcap with your hand to see if they are still warm after playing.
This is a situation seen most often in car audio due to the power levels. How loud is "I am not playing music loud"? -
they smell after listening for about 45 minutes, but smell more if i turn up the volume... -
the towers are ported. i checked the porting and they arent warm. I normally play music and listen to the TV around -20 db...
just want to make sure its not something severe like burning insulation on the wiring or something... -
You might have a cross-over component with a little glue slopped on it that is making some odor. You can call Polk Customer Service and discuss it with them.DKG999
If you want to, crank them but not so loud that you have distortion to (speed up the break-in)/(find out if they're gonna quit on you).
Sounds to me like it is the woofer only that is generating the smell. -
Thought that it might be the woofers as well, which is why i set the crossover for the fronts above 100 (in my HK's menu). Everything below 100 is sent to the sub... -
Smell aside, your bottom woofers are only being used from 100hz to 125hz. I would use a lower crossover frequency, such as 60 or 80hz."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
don't know about that smell but those are not sats, so lower th xover or 80 for sure.
10's I would run at 60-80hz, and I highly recommend an amp for them to take the load off the HK for the rest of the channels. Then run the mains as large(no XO) to get stereo LF out of them.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Currently I am running them large, but set the cross over to over 100 so that the load would be taken off the receiver to power the woofers on the rti10's. Im planning on getting an amp, but not anything soon- tuition for med school comes first!
is there a difference between the large and small setting?
and what is a good amp- i know about adcom and rotels, but do i need 200wpc? If show can you point me out to a good and cheap 2 channel amp please.. -
did you connect the sub with 1 rca type cable? if yes set the xover to small and 80. When you get an amp set it to 60 or lower.
one RCA cable. will give it a shot. out of curiosity, what will this do? reduce the load on the speakers? -
I'm using just a single Digital Coaxial cable to connect my receiver to my DSW Pro 600...to my untrained ear it sounds pretty good"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
ryanjoachim wrote: »I'm using just a single Digital Coaxial cable to connect my receiver to my DSW Pro 600...to my untrained ear it sounds pretty good
Im just using a PSW10 that came with the speakers.
Maybe later i'll upgrade to a HSU or velodyne, but in due time. the amp comes first.. -
Digital coax is 75ohm just like a typical sub cable, should sound fine."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
In order to help you, what is the smell?Im noticing a small smell (cant describe) while playing my RTi10's as fronts.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
its hard to describe, but i want to say it smells like a circuitboard that has been overheated- kinda harsh tuna oil smell or something to that effect.. -
Call Polk CS.Sounds like the crossover.And for gods sake man,lower that crossover to around 70,at 100,it's way too high.HT SYSTEM-
lsi 9's -
I actually had a similar experience when I pulled the RTi10's out of the box. Definitely a "tuna oil"'ish smell coming from the front of the speakers if I got really close to the grills to smell. But the speakers had never been played and after I set them up there was no increase in smell and the speakers have sounded great.
I put a couple of reed diffusers on each speaker and there's no smell anymore. I figured that was that. -
Sorry but this could be an excellent slogan for Bose.
I would call Ken Swauger at POLK CS about your speaks, he definetely does not smell.
RT1 -
Is there a difference between the large and small setting?
And what is a good amp- I know about adcom and rotels, but do I need 200wpc? If show can you point me out to a good and cheap 2 channel amp please..
If you set your front channels as LARGE, how did you also set the crossover to 100? On my receiver and a few others I have seen, once you set the channel to LARGE, there is no longer a crossover option for that channel. Perhaps you set the other channels at 100.
When set to LARGE, you eliminate any filtering by the crossover so you are sending the full frequency. As for the amp, well this question is asked at least 3 times a week so the search option is your friend. I can tell you the two amps that you listed will do well. -
Mine smelled to when i got them. But not like a burned circuit board or cap. More like the construction of the enclosure.Onkyo TX-NR801
Fronts- RTi 10's
Center- CSi5
Rear- Coming Soon
Sub- Velo DPS-10
Pwr- Monster HTS 3600
LCD- KDL-40XBR2 -
With some receivers/preamps, it's possible to set them to LARGE and still adjust the crossover. I believe I was able to with my Onkyo, HK, and Mac.If you set your front channels as LARGE, how did you also set the crossover to 100? On my receiver and a few others I have seen, once you set the channel to LARGE, there is no longer a crossover option for that channel. Perhaps you set the other channels at 100."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Cool... Denon will disable the feature when selected as LARGE. Did you notice a difference with it crossed at say 80 with the front channels set as LARGE then at SMALL?
