3 gnx 12's
saranaz
watup guys.....yea i just bought 3 gnx12's the 4ohms....they were cheap as hell.....anyways....i need sum ideas on what amp or amps to get
Saranaz
Saranaz
Post edited by saranaz on
well you wire them in parallel and you get 1.33 ohms.
so... what's stable at 1.33 ohms and will give you (175 x 3
525 watts ??
the only one that comes to mind that will put out that power at 1 ohm (will actually do it at 2 and 1.. same power, stable at both)... is the JBL BP 600.1 ... i also suggest it because it is cheap as hell as well (since u mentioned u got the subs cheap i figure goin on the cheap is a good thing).
BP 600.1 does 600 watts x 1 into 1 ohm or 2 ohms... 300 x 1 into 4 ohms... cost you like 175 on ebay new in box... prolly 10 bucks to ship it.
mtx 6500D will do like 600 - 650 x 1 into 2 ohms.. and it will remain stable down to 1.3 ohms same as the 81000d, but it's going to cost like 275 ebay / 500 retail and for the applicatioin i dont think it would be as good as the JBL.The Artist formerly known as PoweredByDodge -
hey man where did you pick up your subs? i plan on doing the same setup as youOriginally posted by saranaz
SaranazTesting
Testing
Testing
