What SDA's are these ?
mrbigbluelight
mrbigbluelight Posts: 9,878
edited February 2008 in Vintage Speakers
Local guy says they're SDA 2B SRS's: aren't they SRS 2.3's ?
Size-wise they're 55" tall, heavy buggars.
I've tried the "Search" function on here but, once again, no matter what search term I put in (even tried the word "the"), all I get is "Search Term Not Found". :(
Post edited by mrbigbluelight on
  • Face
    Face Posts: 14,340
    For 3 letter words, add a * at the end of the word, for example, SDA*.
    F1nut Posts: 51,860
    Yes.
  • ben62670
    ben62670 Posts: 15,969
    They are the early ones wher the 4 woofers are on the outsides. The 2 woofers with the bulk chunks in them are bass drivers crossed over low.
    Ben
  • george daniel
    george daniel Posts: 12,096
    Did you buy them?
  • engtaz
    engtaz Posts: 7,669
    Orig 2.3's the top and bottom had doughnut place on them for sonic purposes.
    engtaz
    engtaz
  • BobMcG
    BobMcG Posts: 1,585
    Yup, 2.3s just like mine when they were stock.
  • mrbigbluelight
    Did you buy them?
    I'm emailing the guy, we're going back and forth, he's asking $800.
  • avguytx
    avguytx Posts: 1,628
    I gave $500 for a pair that needed some work on the tops/bottoms but everything else was good to go. I redid all the grill cloth on the sides and for the grills themselves, updated the crossovers, binding posts, etc. The front and back baffles were also very clean. All in all, I guess it's just a matter of how bad you want them.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
