Thoughts on an Acurus amp?
MichFootballGal
MichFootballGal Posts: 14
edited February 2008 in Electronics
I'm ready to admit that I'm addicted.....I just upgraded my system (Denon 2808 powering Rti10s, CSi5, FXi5s and the 500 Pro sub) and am loving it but think I want some more power for the fronts so I'm looking for an amp to power the fronts. My thought is to get something that will tide my cravings (hopefully) for a year and then I'll make a jump to a really nice amp. Locally I found a good deal on a used Acurus A200. While the reviews on these are decent, there are a few that mention the amp being bright. I'm noticing brightness on the Rti's as it is (perhaps because they haven't broken in quite yet), so I'm wondering if anyone has experience with the Acurus amp with the Rti series? Would I be better for now getting the Outlaw monos? Thanks for any insight you may be able to provide!!!
Post edited by MichFootballGal on
  • Early B.
    Early B. Posts: 7,900
    The Outlaw monos and Acurus A200 are at same same level of sound quality, IMO (I've owned both of them). I'd suggest a 5-channel amp. The cost would only be marginally higher.
    "God grooves with tubes."
  • Texas42
    Texas42 Posts: 405
    I have an Acurus A200X3 (3 channel version of the amp you are referring to) and I don't find it bright at all. More neutral than anything else. Now my Adcom amp was kind of bright. Acurus makes (well made) very solid, dependable amps that are very well built and should last you a very long time. Just my two cents...
  • AndyGwis
    AndyGwis Posts: 3,655
    I tell everyone to purchase B&K amps. I've owned a few of the midfi (Parasound, NAD, Carver, etc.) and just like B&K the best in terms of sound, reliability, build quality, etc. Their price for performance seems very good.
    You can find a good 2/3 channel B&K amp for $300 - $400 used. If you'd like some model numbers or suggestions, let me know.
    But, if the Acurus is local, a good deal, and in good condition, get it. If you don't like it, you can always resell it to break even, or even make a couple bucks to put towards your next purchase. Unlike AVRs, Processors, and TVs that have rapidly changing technologies, amps haven't really changed and keep their value very well.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
    heiney9 Posts: 25,412
    Acurus is a solid well built performer. For your needs your really can't go wrong with it.
  • george daniel
    george daniel Posts: 12,096
    the acurus is a well built piece of gear,,I did not think my was bright at all. Good luck
  • MichFootballGal
    Thanks so much for the all information so far. I don't know where I'd be without this forum....oh wait, yes I do.....I'd probably have a lot more money in my pocket (since I've already bought much more than I originally planned) :D
