2 mm124's
Systems
Systems Posts: 14,873
edited March 2003 in Car Subwoofer Talk
im looking into two mm124's. i am wondering how these will do in a ported box. if they work well in ported box's could you send me plans of an example? thanks
Testing
Testing
Testing
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited December 2002
    well, you'd be hard pressed to find anyone who will endorse a momo in a vented enclosure... and the polk reps themself will tell you they dont reccomend it at all. they push sealed or bandpassed -- most anyone else will harp on sealed for the momo.
    The Artist formerly known as PoweredByDodge
  • cedric
    cedric Posts: 11
    edited March 2003
    the answer is no on ported, trust me. u will be replacing the sub if u do
