Toshiba Ouput Tranistors 2SD424 & 2SB554 (many Adcoms)
1246
  • Systems
    Systems Posts: 14,872
    edited January 2008
    ben62670 wrote: »
    IRF244, and IRF9240
    What about them?They are IRC Mos or Hexfets as IRC likes to call them.
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Can you guys learn me something real quick?
    Looking the MOSFET in pictures and on my older Hafler amp, I believe what I saw was, sorce gate and dump, 3prong. I noticed your bi polar only has 2 prongs. Why is that? Or am I thinking of something totaly different?
    or is this stricly design for the board?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    jakelm wrote: »
    Familiar with the MOSFET, sorce gate and dump, 3prong. I noticed your bi polar only has 2 prongs. Why is that? Or am I thinking of something totaly different?
    The case is the 3rd leg. 85VDC taught me that one:eek:
    Ben
    heiney9 Posts: 25,522
    edited January 2008
    ben62670 wrote: »
    They are actually hexfet. I like my 585 over my 5800 anyday.
    Hexfets are used for the front end not the final output stage on the MosFet Adcoms. 5xxx series.
    MosFets can have the exact same T03 metal can and I believe the 5800 is MosFet, just can't remember and am too lazy right at the moment to look it up.
    5802 is MosFet.
    edited January 2008
    jakelm wrote: »
    NM, reading comprehension is a bit low right now:eek:
  • Systems
    edited January 2008
    jakelm wrote: »
    Bi polars also have 3,the base ,emitter and collector.
    Testing
    Testing
    Testing
  • Systems
    edited January 2008
    Hafler where one of the first to use Mos Fets ,I think Mr Borbely designed the early Mos stuff for them.
    Testing
    Testing
    Testing
  • Systems
    edited January 2008
    heiney9 wrote: »
    MosFets can have the exact same T03 metal can .
    Yes I think that has been pointed out a couple of times already.:rolleyes:
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Well, I couldnt tell you which was better, but I do know I cant kill my Hafler. I dont know if that has anything to do with the tranny's. I can cook an egg on it, but cant kill it..
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    edited January 2008
    jakelm wrote: »
    Yep they are robust and reliable once you get them soldered into the circuit.They are very static sensitive and must be handled with care during assembly.
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    GV#27 wrote: »
    Well its a good thing I didnt assemble it, becides installing new input caps and new PC caps and power switch. I have taken it apart a million times.
    I handle nothing with care...lol
    But that old black metal case is hard to dent and scratch.
    sorry for the hijack Ben... carry on..
    I thought I smelt a debate brewing.... to stop on my acount...lol
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Systems
    edited January 2008
    ben62670 wrote: »
    IRF244, and IRF9240
    Is that the part number on those outputs?Then they is Fets.
    Testing
    Testing
    Testing
    edited January 2008
    GV#27 wrote: »
    Alrighty then :rolleyes:
  • ben62670
    edited January 2008
    GV#27 wrote: »
    Ya got me:D
    Non common ground either. Can the grounds be tied together?
    Ben
  • Systems
    edited January 2008
    ben62670 wrote: »
    Ya got me:D
    Ok you posted 2 part numbers IRF244 and IRF9240 .Then later you added the pick of your amps output transistors.I can't read the numbers on those outputs but if it is the stated part numbers then they are Fets.Comprondy?:D
    Nope.
    Testing
    Testing
    Testing
    edited January 2008
    ben62670 wrote: »
    Ya got me:D
    Yes they can. 5800, 5802, 565 all can be tied together. Ask DarqueKnight and HearingImpaired. I would assume the 585 could be too, but that's one I've never checked on.
  • ben62670
    edited January 2008
    GV#27 wrote: »
    DNope.
    Please!!!!!!!!!!!!!!!!
    Those are the correct part numbers from the TO3 Misfits:p I looked up the data sheet on them, and they called the hexfets:confused: I must resit the urge to tie grounds together:mad::mad::mad:
    Well SDA cable disconnected the 5800 hits faster than the 585, but sounds much more edgy which really sucks, because I would like to drive the stereo array with the smoother GFA-585, and the dims with the 5800, but that will not work:(
    BTW... spell check substitutes misfits for mosfets. I think that is kinda funny:D
    Ben
    edited January 2008
    ben62670 wrote: »
    Contact Adcom abut the 5800, but I am 1000% sure the 5802 and 565 can be tied together. The 5802 is just an updated version of the 5800 and the topology is essentially the same. They moved the cooling fins outside the case and got rid of those twin fans and tunnel effect cooling. They did some tweaking with the 5802 but it's essentially the same as the 5800. Both are Nelson Pass enhanced designs.
  • ben62670
    edited January 2008
    heiney9 wrote: »
    Don't have to with the 585. All grounds are tied together internally:)
    OK It's going to kick A$$, or I am going to smell smoke. At 2.6ohms this is a confirmation test of the safety of tying ground together on 5xxx MOSFET amps:D
    Ben
  • ben62670
    edited January 2008
    No Smoke! Sounds fine. A little edgy, but I am listening to Sting, and he records a little hot.
    Ben
  • Systems
    edited January 2008
    ben62670 wrote: »
    As I mentioned earlier IRC (International Rectifier) call their Mos Fets HEXFETS they are the same thing:)
    I must resit the urge to tie grounds together:mad::mad::mad: I
    Amps that have bridged output stages should not have their negative terminals joined.Don't know if your 5800 uses such an output stage though.But is there not a special cable for using non common ground amps with SDA's.?
    Testing
    Testing
    Testing
    edited January 2008
    GV#27 wrote: »
    None of the 5xxx series (2ch) have bridged output stages. Some of the HT amps might to configure for a subwoofer, etc.
    The only bridgeable 2ch amp from Adcom was the 555 and that would be a no no (as Engtaz found out :D) to tie the terminals together when running (2) a mono blocs.
    Again some of their HT amps had 1,2 or 3 channel configurations so I'm not counting those. Not sure if the original GFA1 and GFA2 were bridgeable. I've never had reason to learn much about those very first Adcoms.
    AI-1 is the special cable to use with non-common ground amps that CAN"T have their negative terminals tied together.
  • hoosier21
    hoosier21 Posts: 4,422
    edited January 2008
    ben62670 wrote: »
    a little? toooooo szippy for me on most of his.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Systems
    edited January 2008
    heiney9 wrote: »
    Many high powered amps have bridged (also called balanced) output stages so that they can get the 500 watt output.Each of the 2 channels is made up of a bridged pair of output stages. Bryston, Pass Labs, Musical fidelity all do this on their bigger amps.
    Testing
    Testing
    Testing
    edited January 2008
    GV#27 wrote: »
    I agree, but Adcom's, to my knowledge, aren't set up this way and can have the negative terminals strapped to accommodate SDA's.
    DarqueKnight ran his 5802 strapped before getting an AI-1 cable and Hearing Impaired strapped his 565's when he had them. I believe there is a member who has a 5500 strapped for his SDA's as well.
    The 5500, 5800, 5802, 565's (of course they are mono's) are all Non-common ground designs. It's my understanding that because they have a secondary or multiple secondary windings (rahter than 2 separate transformers) in these models they don't share a common ground at the speaker output. But there isn't an issue sharing the ground by strapping.
  • Systems
    edited January 2008
    Damn that is just way too many 5** something or other model numbers to keep track of.:confused:
    Testing
    Testing
    Testing
    edited January 2008
    GV#27 wrote: »
    LOL-
    5200- common ground; no secondary trans winding
    5300- " " " " " "
    5400- " " " " " "
    5500- Non-common ground; secondary trans winding(s); strappable
    5802- Non-common ground; secondary trans winding(s); strappable
    565- Mono Bloc non-common ground by design; strappable
    585- Not sure but Ben states it has a common ground.
    535, 545, 555 common ground
    555- if run in bridged mode is not common ground and the neg terminals can NOT be strapped.
    Disclaimer: this is what I've learned doing some research here and at DIY audio. If in doubt either measure using VOM at the output terminals or contact Adcom. I will not take any responsibility for the above statements being inaccurate. :)
  • Systems
    edited January 2008
    Apparently you don't suffer from alziemers to remember all of that.I have to stick to the numerically much simpler Bryston line,2B, 3B,4B,6B,9B all common ground. 7B,14B,24B,28B non common ground and not strappable.
    Testing
    Testing
    Testing
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Very easy way to find out if its common ground. Ben, you already have the top off. Put the meter to it.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Face
    Face Posts: 14,340
    edited January 2008
    Or just hook it up to SDA's. :D
